JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Tyre pressures - URGENT!
reganlives
15-01-2019, 11:00 AM
I'm getting my car sorted out today and getting the mot done as well so will be putting my new TTE Grand Prix 18" wheels on but what pressure should I have the tyres set to? I know that wim recommends 35psi all round for the standard 17s but what about 18s?
Please can someone let me know asap as I'll be putting the wheels on in about an hour.
reganlives
15-01-2019, 11:00 AM #1
15-01-2019, 11:09 AM
I had 35psi on my 18" rims - no problems.
15-01-2019, 11:09 AM #2
15-01-2019, 11:17 AM
i run 36psi front and 35psi rear
15-01-2019, 11:17 AM #3
TommyH
15-01-2019, 11:44 AM
I run 33psi all round on 18s. IICRC Tony reccommended this to me a while back.:confused1:
TommyH
15-01-2019, 11:44 AM #4
James S
15-01-2019, 12:20 PM
35 seems very high, is this on standard cars? I think I only got about 30 in mine. :confused:
James S
15-01-2019, 12:20 PM #5
15-01-2019, 02:09 PM
WIM settings for both 17 and 18s (225/45/18) is 35 all round Smile
15-01-2019, 02:09 PM #6
15-01-2019, 02:10 PM
I keep my tyres around front 30 - rear 32 for this time of year
And i push this up around 32 -34 in the summer
15-01-2019, 02:10 PM #7
15-01-2019, 03:01 PM
35 all round in my 18s, which I believe are the same size as the grand prix ones.
15-01-2019, 03:01 PM #8
Tango
17-01-2019, 03:40 PM
35 psi all round is a proven starting point for 17" & 18" on the IS200, but you still need to monitor the wear pattern on a regular basis and adjust up or down depending on whether the tread is wearing more on the inside & outside edges or in the middle. Variation can be the result of rubber compound, usual driving speeds and the duration of journeys.
Tango
17-01-2019, 03:40 PM #9
Replies 25
Views 1,754
07-08-2020, 07:00 PM
Last Post by Chris0121
Views 577
20-03-2020, 09:37 AM
Last Post by Mikey
Views 1,337
20-07-2019, 11:53 AM
Last Post by speedfreek
Views 688
08-07-2019, 06:11 PM
Views 1,122
11-04-2019, 06:19 AM
Last Post by Phil01
Views 1,520
11-03-2019, 11:14 AM
Views 1,042
14-09-2018, 03:35 PM
Last Post by Fry-Up
Views 1,788
15-05-2018, 03:23 PM
Last Post by Fry-Up
Views 1,525
03-03-2018, 03:55 PM
Last Post by wahidhussain
Views 1,008
06-07-2017, 01:11 PM
Last Post by Davros
