JapCarForum Trade Area Trade Archive Selling Archive Vibe, Hifonics, audiocontrol equipment.
22-01-2018, 04:43 AM
Vibe AC10 EVO enclosure
10" SPACE II subwoofer in custom made original box
SPECIFICATION:
SPACE II 10" Subwoofer
Height: 370mm
Width: 465mm
Bottom Depth: 415mm
RMS Output: 500w @ 4 Ohm
TurboPorts: 1
All items in great condition, only been installed since August 2010.
This sub will out perform many far bigger and expensive subs - it is very loud and offers very deep bass. In fact I have the Bass turned down a bit because it generates so much!!
£100 - ono.
For £130 I will throw in the Hifonics BXi Pro 1.0 bass restoration machine - does exactly the same as the Audio control epicentre that Wozza uses - this is the secret to optimising bass in your cars when listening to MP3 and other compressed media.
For £200 You get the Sub, BXi Pro 1.0 AND the Hifinics amp. This combination is the perfect budget set up.
For £230 You get the sub, BXi Pro 1.0, sub amp AND Audio Control LC6 (1 output channel not working - this is not an issue if 1 of your amps has a loop through 90% do)- converts and merges line level to RCA so no need for amp by-pass leads in the IS200 or any other car true OEM integration.
For £350 You get all the above and the Vibe Litebox 4 channel limited edition 4x90w (4Ohm) 4x 125w(2Ohm) Amplifier. All cables, fuses, and all mounted on a MDF amp rack trimmed in black. Pre wired just add line or speaker level inputs.
BARGAIN.
Can deliver if fuel is compensated for, as its a Pruis fuel isn't that much!!!
If the above deals don't go to club members then they will be listed on Ebay separately.
Pictures to follow.
22-01-2018, 04:43 AM #1
SPECIFICATION:
Height: 370mm
Width: 465mm
Bottom Depth: 415mm
TurboPorts: 1
£100 - ono.
BARGAIN.
Pictures to follow.
14-02-2018, 05:29 AM
Only sub woofer left.
14-02-2018, 05:29 AM #2
14-02-2018, 05:33 AM
Tempting... I could replace both vibes in my car with that and free up space behind a seat!
Need to check the depth and get back to you
14-02-2018, 05:33 AM #3
14-02-2018, 06:06 AM
its far to big to get into a MR2 unless your removing the seat altogether.
14-02-2018, 06:06 AM #4
14-02-2018, 06:13 AM
I was really only thinking about the sub itself, not the enclosure.
14-02-2018, 06:13 AM #5
14-02-2018, 06:51 AM
Then I would be left with a useless enclosure?
lets see it it will sell then split it if necessary.
14-02-2018, 06:51 AM #6
14-02-2018, 08:48 AM
lol, I meant I'd take the lot off you, but I'd only *use* the sub. But that obviously depends on whether it'd fit in my existing enclosure, etc etc
14-02-2018, 08:48 AM #7
14-02-2018, 08:57 AM
ok..............
14-02-2018, 08:57 AM #8
ok..............
Views 186
13-01-2019, 01:13 PM
Last Post by Dark Samurai
Views 507
16-04-2018, 06:58 AM
Views 560
01-04-2018, 10:50 AM
