JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Repainting calipers black from red....
karlp
31-01-2018, 05:13 AM
Bit tired of my red calipers now, thinking of going glossy back as wanting to get wheels refurbed either back silver or white.
Whats the best way to strip current paint off and apply now?
Just go straight over the top with some more hammerite?
karlp
31-01-2018, 05:13 AM #1
31-01-2018, 05:21 AM
Run a drill with a wire wool bit over them to take the majority off first then paint, I'd guess...
Jim (jimxms) did this recently and went from red to silver, there's a thread around somewhere for it...
31-01-2018, 05:21 AM #2
karlp
31-01-2018, 05:43 AM
or give it a good scurb with wire wool? rinse, dry, repaint?
anybody got a full set of lexus caliper stickers in white/silver?
karlp
31-01-2018, 05:43 AM #3
posty
31-01-2018, 06:00 AM
ebay do...
http://cgi.ebay.co.uk/LEXUS-Brake-Calipe...51983b1203
31-01-2018, 06:44 AM
DaveEdin Run a drill with a wire wool bit over them to take the majority off first then paint, I'd guess...
Aye, I'd totally recommend getting a cheap set of wire brush drill attachments in various sizes and shapes. I got a set from eBay for about £5.
I also bought some STP Brake Cleaner for cleaning off all the dust and dirt once you've rubbed them down. it works well and dries really quick, so there's no need to wait ages before painting.
My process was a bit like this:
- Cover area of car you are working on with a large blanket. Even though its only paint dust that will be coming off when you rub them down, It doesnt take much imagination to work out what will happen if your car is covered in red paint dust and it rains :p
- Remove the wheels (using the usual precautions)
- Take straight to the calipers with a corded drill and the wire brush attachments. I went all the way back to bare metal when I did mine so I could get a perfect finish. But as long as you've got a 'keyed' surface for the new paint, you can probably get away with not going that far.
- Heavily spray the whole area with the STP brake cleaner. This will make a really big oily/paint puddle on the floor, so if you've got a nice driveway be sure to get plenty of cardboard on the floor.
- Once the brake cleaner has dried <5mins, use masking tape on the brake disk face.
- Use cardboard to enclose the wheel arch area (to prevent the wind from affecting the paint spray direction). Also make sure it covers areas of the wheel arch and suspension that you dont want to get covered in paint.
- Cover as much of your car as possible in sheets to avoid any overspray. Its 10x harder to remove caliper spray paint than it is normal spray paint from your cars paintwork (as I found out).
- Spray light coats on the calipers about 5-10 minutes apart to get a get an even coverage. I used Halfords caliper spray paint - which was really good!
- Leave them to dry for about 3 hours, then take the car for a quick drive around the block (if the weather is ok) to prevent the calipers from gumming up.
- Leave then to try properly for another 10hrs or so before attempting to apply caliper decals.
31-01-2018, 06:44 AM #5
karlp
31-01-2018, 07:00 AM
I used hammerite out the tin and painted them in using a fine brush, would this be okay or is spray best?
karlp
31-01-2018, 07:00 AM #6
31-01-2018, 09:11 AM
Nothing wrong with the paintbrush method, I just decided to go the spray paint route as I found it much easier to get an even coat.
31-01-2018, 09:11 AM #7
31-01-2018, 10:21 AM
shame i live so far away as i will paint mine red from black soon . hope it goes well
31-01-2018, 10:21 AM #8
karlp
02-02-2018, 12:21 PM
fancy doing a post swap Jay?
My red for your black, its hammertie smooth red and more than half a tin left..
LMK
:thumbup1:
karlp
02-02-2018, 12:21 PM #9
LMK
:thumbup1:
02-02-2018, 09:41 PM
oh sorry mate i meant clipers, the paint is finished.
02-02-2018, 09:41 PM #10
Views 328
22-06-2020, 11:56 PM
Views 236
18-12-2019, 01:00 PM
Views 1,129
27-05-2018, 04:57 AM
Last Post by Stoney
Views 312
07-04-2018, 02:14 AM
Last Post by jimxms
Views 346
16-02-2018, 06:51 AM
Last Post by Bandit
Views 659
14-09-2017, 09:46 AM
Last Post by Fry-Up
