JapCarForum Club Sponsor Auto Rae Chem Kranzle k7/120
Kranzle k7/120
Kranzle k7/120
AutoRaeChem
01-02-2018, 03:52 AM
The K7/120
Operating pressure 120 bar/1800 psi fully adjustable
3600 epsi equivalent pressure with the DirtKiller lance
20 degree spray angle (nozzle size 03)
Water flow 7 Ltrs/Min. @ 1400 rpm
Max inlet water temp 60oc
Max suction height 2 m
High pressure hose 10 m steel braided, rubber coated
Chemical/detergent system - Optional
Supply 230-240v 7.5 amps 1ph 50 Hz
Connection load 1.6 kw
Motor output 1 kw
Weight 18.5 kg
Dimensions 440 x 200 x 330 mm
[Image: HD7-120.jpg]
SPECIAL SUPPLY PRICE OF £429.00 INC VAT & DELIVERY* UK MAINLAND ONLY
TO ORDER ONE JUST SEND A PAYMENT TO PAYPAL THE USUAL WAY TO [email protected]
Edited 16-03-2011, 10:20 AM by AutoRaeChem.
AutoRaeChem
01-02-2018, 03:52 AM #1
The K7/120
Motor output 1 kw
Weight 18.5 kg
Views 82
04-10-2020, 07:00 AM
Last Post by AutoRaeChem
