JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Mileage correction
Mileage correction
Mileage correction
Pages (3): 1 2 3 Next
bash6673
03-02-2018, 08:21 AM
I bought a new speedo a while back, but I need to get the mileage corrected on it to reflect the current and true mileage.
I was in touch with a guy called Ibby on here a while back,but he no longer appears to frequent the forum.
This is quite legit as the current mileage is higher than what is presently on the new speedo.
Can anyone help or point me in the right direction me to get this sorted?
Cheers.
[Image: 15hzu5z.jpg]
bash6673
03-02-2018, 08:21 AM #1
Cheers.
03-02-2018, 08:54 AM
I cant help but interested in the results as ive got a rising sun set of dials to sell
03-02-2018, 08:54 AM #2
03-02-2018, 09:03 AM
if yours is the same style as the old one why not just change over the front part
03-02-2018, 09:03 AM #3
bash6673
03-02-2018, 09:31 AM
Changing the speedo face won't make any difference.
The mileage is stored on a chip on the speedo and not in the ECU.
The original speedo is an XE03. The new one is an XE03-A.
The mileage on the original speedo is higher than what is stored on the new one.
bash6673
03-02-2018, 09:31 AM #4
03-02-2018, 09:41 AM
I think Jay was suggesting that you shift the stainless steel dials across to your existing clocks... then the mileage would remain correct?
03-02-2018, 09:41 AM #5
03-02-2018, 09:46 AM
but are they not the same style just different fronts? because you can take the fronts of and change them over
03-02-2018, 09:46 AM #6
03-02-2018, 09:47 AM
[Image: SDC12102.jpg]
03-02-2018, 09:47 AM #7
03-02-2018, 09:48 AM
[Image: SDC12107.jpg]
[Image: SDC12106.jpg]
[Image: SDC12101.jpg]
03-02-2018, 09:48 AM #8
03-02-2018, 09:49 AM
you can remove the fronts like i did no problems. just put the fronts on and leave the clock alone
03-02-2018, 09:49 AM #9
bash6673
03-02-2018, 09:50 AM
DaveEdin I think Jay was suggesting that you shift the stainless steel dials across to your existing clocks... then the mileage would remain correct?
The stainless steel dials were from the original (XE03) clocks.
I want rid of the original speedo to put the new (XE03-A) one in, but I need to update the mileage on the new one.
Original speedo=95k
New speedo=89k
I wan't the new speedo to have the same mileage as the original ie; 95k.
Apologies to all if this appears to be confusing.:biggrin:
bash6673
03-02-2018, 09:50 AM #10
Original speedo=95k
New speedo=89k
