FS: 2nd Gen IS push switch
I have 2 of these cost me a fair bit last year whilst i was designing the push start circuit for the IS200.
Thes can be wired up to just activate a relay to start the car, or if you are a bit more creative you can also make the LED's function along side the factory wiring of the car.
looking for about £70 per switch delivered via Next day courier
it does depend on what you want it to do, if you just want it to crank the car i.e use the key to turn the car on but push the button and hold to crank it to start it very easy only 2 a couple of wires and a relay
