IS200 SE Parrot Bluetooth Kit
Guys,
Im after some advice please. I have my Is200 with factory nav, dvd conversion for the screen and 2 RCA sets out. Once for DVD audio and the other has a RCA to 3.5mm jack to connect mp3 player.
I want to install the Parrot MK6000 kit in the car which has bluetooth audio streaming.
I am getting conflicting advice from people on if this kit is possible to fit etc. because of the factory amp. What i want is the telephone audio to come through the front speakers and when streaming audio all the speakers. If i want to activate the AUX, i use the disc button on the factory head unit to switch between the AUX inputs. The AUX box uses the MD changer control on the back of the unit.
Can someone advise if what i want is possible? I dont mind switching the AUX input on to have the bluetooth streaming come through all the speakers, but telephone as to cut the sound so i can hear the call from the fronts.
Cheers
Can you check with parrot what the two pairs of line-outs do? Is one pair for phone and the other for music or do they both work together?
Also if your telemute lead is the same as mine it'll have a nokia plug on the end, in which case you might need one of these too
http://www.carcommunications.co.uk/store...-2480.html
Nice one mate, was the installation quite straightforward? And did you change the kit then? Thought you had an MK6000?
Have you got another phone you can test it with?
