The quick contactless wash!
Summer is on its way, and with it comes the annoyance of having a car that gets covered in dust and pollen immediately after you've just finished detailing it.
Under normal circumstances, someone as a.n.a.l as me would perform a complete wash of their car every few days using the two bucket method, followed by drying the car off with microfibre cloths and detailing sprays.
However....today I have experimented with a quicker way. Observe....
Step #1 (optional)
If you've got a snowfoam lance attachment to your pressure washer, snowfoam the entire car and leave it to loosen up as much dirt as possible before it starts drying (normally 5-10mins).
Step #2
Jet wash the entire car, paying particular attention to the areas that get the most dusty (lower parts of panels, rear bumper, boot...etc). Once this is done, you can also use the 'sheeting' method where you run a slow but steady stream of water over the car direct from the hose to produce large water droplets.
Step #3
Grab one of these bad boys. A 2200w leaf blower from Argos which blows at over 200kmph!
Step #4
Blow as much water off the car as you possibly can. The best thing about using a leaf blower on your car is that it can push water out of all those annoying areas where it normally drips from shortly after you've finished leathering off the car
Step #5
Stand back and admire the quick wash that didn't require any buckets of water, any sponges, any cloths or leathers.
Lexuspat what a result jim i think this should be the new method instead of the two bucket its now the leaf blower method
thats my kind of washing!!
I would think the paint will be well looked after also as your not using mechanical force to remove dirt................
2tongues thats my kind of washing!!
looking good mate...stunning car......
is it just the wat the pic has been taken but the exhaust looks like its sitting funny??off center?
ormi is it just the wat the pic has been taken but the exhaust looks like its sitting funny??off center?
nope your correct mostly happens to exhausts that have been posted,the brackets get slightly bent..
