JapCarForum Trade Area Trade Archive Selling Archive FS: Apexi Neo AFC (piggyback)
16-02-2018, 11:58 AM
Bought this a few months ago to eeek every last bit of HP out of the N/A IS300 engine. But now as I'm going the S/C route which comes with its own piggyback controller so this is surplus to requirements.
  • If you've got an IS300 and live local, I'll help you install this.
  • If you've got an IS200, live local and can get the ECU pinout diagram, I'll help you install this.
  • If you've got an IS300 but live far away, I'll give you all my instructions and notes for installing it (its very easy).
  • If you've got an IS200 but live far away, I'll try and help my best.
[Image: l_img_0174.jpg]
[Image: l_img_0180.jpg]
[Image: l_img_0181.jpg]
[Image: l_img_0189.jpg]
[Image: l_img_0179.jpg]
It cost £300 new, will let it go for £200 just so I can put the money towards a wideband.
Original box, instructions and wiring loom included.
16-02-2018, 11:58 AM #1
James S
16-02-2018, 08:52 PM
I'm interested. Does it require mapping or a mechanic to set it up once installed?
James S
16-02-2018, 08:52 PM #2
16-02-2018, 09:12 PM
You can go and get it dyno tuned for the best results, however I'm using some conservative 'known safe' settings to lean out the fuel 5-7% across the rpm range.
Once you've got it hooked up there really is nothing more to it. Takes all of 5 mins to work your way around.
Edited 31-03-2011, 07:45 AM by jimxms.
16-02-2018, 09:12 PM #3
James S
16-02-2018, 11:26 PM
Ok, so a pro can set it up on a dyno, like a unichip? But it's got functionality to do a bit of basic tuning yourself?
Defo interested, I'm off on holiday tomorrow for a week, so if it's still here when I get back i'll have it off you. Smile
James S
16-02-2018, 11:26 PM #4
16-02-2018, 11:35 PM
Yep that's basically the long and short of it.
From what I've heard, the IS's tend to run quite rich so you can safely lean out by about 5-7% around the middle of the RPM range (2000-5000rpm) and 1-3% elsewhere. Obviously if you have an intake/exhaust you can also make better use of those too.
Then if you want to go a step further, you could get it pro tuned - or - grab yourself a wideband with logging capabilities and then look at where you are still running rich. On the IS300 some people have been able to lean out by 12% at certain points.
I'm in no massive hurry to shift it yet. So long as its sold by the time my supercharger arrives I've no problems with keeping it aside.
16-02-2018, 11:35 PM #5
James S
16-02-2018, 11:38 PM
Do you want a deposit? I'll take it off you hands when I get back from holiday. :-)
James S
16-02-2018, 11:38 PM #6
16-02-2018, 11:44 PM
If you're 100% sure you want it, and your holiday isn't in Las Vegas (where you might gamble away all your money). Then I'm happy to hold it on your word mate.
16-02-2018, 11:44 PM #7
James S
17-02-2018, 12:01 AM
Nope, not going to Las Vegas! I don't gamble anyway mate. Just a nice family holiday. :-)
How much work is involved in the fitting? Would I need an auto electrician to wire it up?
James S
17-02-2018, 12:01 AM #8
17-02-2018, 12:44 AM
It took me about 3 hours, and I'm by no means competent in auto electrics.
The hardest part is routing the wires really. You will need a metal coat hanger to help you pull them through the rubber grommit on the firewall and then make a hole in the split loom that goes into your ECU box. Then its just a matter of soldering a few wires - or using posi-taps like I did.
If you like I can take some pictures when I remove it, just so you've got something to refer to.
17-02-2018, 12:44 AM #9
James S
17-02-2018, 12:57 AM
That would be spot on. Does it just connect to certain wires on the ecu? And does it come with a loom or wires long enough to reach the ecu? Lol, and how many wires are there to connect?
James S
17-02-2018, 12:57 AM #10
Views 804
11-05-2019, 11:31 AM
Last Post by Silent Tuner
Views 418
27-09-2018, 06:26 AM
Last Post by FunkMasterJay
Views 1,549
11-04-2018, 08:16 AM
Last Post by James S
Views 189
03-06-2017, 02:52 AM
Views 218
28-02-2017, 12:16 PM
Last Post by Chri5
