JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Altezza Diff Query
Altezza Diff Query
Altezza Diff Query
daz
17-02-2018, 03:43 AM
Hi all, a friend of mine has started to attend some drift sessions in his RS200, however he is experiencing some problems.
He reports only one wheel spinning although his chassis number denotes A01B
Now the car is 12 years old, so there is a chance that its been changed for an open diff in the past, how can he tell what diff he has?
and what diff will he need for his drift car?
Cheers
daz
17-02-2018, 03:43 AM #1
Cheers
17-02-2018, 03:47 AM
The only way to tell which diff is in there is to open it up.
If it is an Altezza diff the case is in fact slightly different to the IS200 - the Altezza one has heat fins on it the IS200 one is smooth.
17-02-2018, 03:47 AM #2
daz
17-02-2018, 05:31 AM
Ok I'll have a look to see if it's got fins, how would you tell if it's a LSD though other than driving it, does the is200 diff fit, if so are these all LSD or only available on sports?
Cheers :-)
daz
17-02-2018, 05:31 AM #3
Cheers :-)
17-02-2018, 05:52 AM
Only the Sport came with an LSD - even then it was only an "option" from the factory on the earlier models.
The ONLY way to tell is to open it up and see what's inside it - its a torsion type so jacking the car up and spinning a wheel will not tell you anything.
The Diffs are completely interchangeable, only the drive shafts are different - one has 4 studs the other 6 studs but the bit the drive shafts bolt up to are easy to swap over.
17-02-2018, 05:52 AM #4
daz
17-02-2018, 06:31 AM
Cheers pal, just spoke to him about fins etc he was a little confused so I'll have a look for him, he said it looks like fins on the side but I'm sure these are probably casting marks and the fins would be on the rear of the diff?
Are there any part numbers etc on the diffs? Just thinking how to identify a LSD at a breakers yard or fleabay lol
Cheers
daz
17-02-2018, 06:31 AM #5
Cheers
17-02-2018, 06:38 AM
They are underneath the Diff, fairly obvious when you look at it.
17-02-2018, 06:38 AM #6
Views 345
06-08-2022, 11:58 AM
Last Post by Brad92
Views 388
18-10-2021, 02:04 AM
Views 342
03-09-2021, 07:20 PM
Last Post by Ratchet
Views 270
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 303
05-12-2019, 02:23 AM
Last Post by Reject1970
Views 344
01-10-2019, 05:15 PM
Last Post by PETEHAMASAKI
Views 496
10-09-2019, 07:51 AM
Last Post by gazzarose
Views 679
21-07-2019, 10:57 AM
Last Post by Chris0121
Views 441
18-06-2019, 03:14 AM
Last Post by Kevpr
Views 414
23-05-2019, 12:27 PM
