JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Where can I get 12v IGN behind the glove box?
23-02-2019, 04:35 PM
So my big bundle of PLX stuff for monitoring AFR/EGT/BOOST has arrived and I've found a nice little place to hide them away behind the glove box.
Question is, does anyone know what wires I can tap into there to get a decent 12v IGN feed? All the wires look pretty beefy and I doubt the PLX stuff consumes much.
Any ideas?
23-02-2019, 04:35 PM #1
Any ideas?
23-02-2019, 04:42 PM
Why not route it across from the stereo?
ive got that much stuff now i use the switched 12v from the radio to power a relay that connects a live from the battery to a separate fuse box.
23-02-2019, 04:42 PM #2
there is a IGN feed on the factory Amp cabling or you could take a feed form the radio / cigarette lighter feed
Edit: or do what stav says thats what i did in mine and i also did the same in wozza's car...
23-02-2019, 04:42 PM #3
23-02-2019, 04:52 PM
Cheers boys. I'm looking to draw 30w, should the amp/radio feed be able to cope with that?
The whole switched feed is beyond me tbh.
EDIT: Also, how hard is it to route a cable from the drivers side of the dash (near the A pillar) over to the glove box? I had a quick look this evening and I couldn't see any direct route?
Edited 06-04-2011, 08:42 PM by jimxms.
23-02-2019, 04:52 PM #4
23-02-2019, 05:00 PM
you can route through the top of the radio section if you remove the dash tray alterativly there is a route through above the transmition tunnel about half a foot back from the atart of the dash
23-02-2019, 05:00 PM #5
23-02-2019, 05:04 PM
Rabster you can route through the top of the radio section if you remove the dash tray alterativly there is a route through above the transmition tunnel about half a foot back from the atart of the dash
Nice one mate. This is beginning to look a bit easier than I initially thought.
23-02-2019, 05:04 PM #6
