JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Side skirts
Side skirts
Side skirts
bash6673
26-02-2018, 01:10 PM
[SIZE="4"]Fitting them tomorrow.
TRD ones.
I did a search but found no info.
Does anyone have fitting instructions or a write up for putting them on correctly?
I seems straight forward enough,just want to make sure it is done properly.
Thanks.[/SIZE]
Edited 09-04-2011, 10:59 PM by bash6673.
bash6673
26-02-2018, 01:10 PM #1
TRD ones.
Thanks.[/SIZE]
26-02-2018, 01:40 PM
Very straightforward matey. Ormi fitted mine for me recently, they basically just bolt into the pre-existing holes where the arch liner is. Word of warning, the front arches have a set of plastic spacers attached, and you will need them to fit the skirts properly...
For extra strength, you can place tape along the top of the skirts to ensure a nice tight fit all the way along.
26-02-2018, 01:40 PM #2
bash6673
26-02-2018, 01:54 PM
[SIZE="4"]Dave,thanks for the info.
You wouldn't happen to have any pics of them fitted showing where they sit on the front and rear arches?[/SIZE]
bash6673
26-02-2018, 01:54 PM #3
26-02-2018, 03:04 PM
Bit late to go taking pics now, but I can do it in the morning if you want..
In the meantime, you can see a writeup with a couple of pics here, about halfway down the page...
26-02-2018, 03:04 PM #4
bash6673
26-02-2018, 08:35 PM
[SIZE="4"]Yeah that would be great.
I thought you might have had some from when your own were fitted.
Thanks again.[/SIZE]
bash6673
26-02-2018, 08:35 PM #5
27-02-2018, 01:46 AM
Heh you might think that, but I was too busy blethering with Ormi to remember to take pictures anyway...
I'll nip out just now and take a couple pics of where the fittings are on the front and rear arches...
27-02-2018, 01:46 AM #6
27-02-2018, 02:53 AM
Front Arch (Note black plastic spacer)
[Image: IMAG0505.jpg]
Rear Arch (Only the one bolt on, means no messing about with the second and needing to drill into arches etc; the skirts stay on fine with the bolt and the extra strong VHB tape)
[Image: IMAG0506.jpg]
No pics of the underside fixings, as they're not fitted on there; again the tape and arch bolts are solid enough.
Scuse the mud... :kiltsmilie::kiltsmilie:
27-02-2018, 02:53 AM #7
bash6673
27-02-2018, 03:08 AM
Cheers for that Dave.:thumbup:
bash6673
27-02-2018, 03:08 AM #8
27-02-2018, 11:58 AM
Ah, but skirts from an IS being broken on fleabay don't arrive with a fitting kit Gord :lol:
So I had no plate to fix with, besides it'll be fine as is Smile Ormi said so. Smile
Makes you wonder why they didn't just put the hole somewhere it'd just fit into the arch itself, rather than some plate...
:offtopic: Did you get the address details you needed Gord?
27-02-2018, 11:58 AM #9
Views 454
12-03-2021, 11:09 AM
Replies 36
Views 2,360
23-07-2018, 06:09 AM
Last Post by S
Replies 40
Views 1,953
05-01-2018, 08:03 AM
Last Post by reganlives
