JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Slow starting
Slow starting
Slow starting
clossie
14-03-2018, 11:35 AM
Just thought I would poll you guys for your opinions before I head to a garage.....every time I start up, it takes a good 2 seconds/2-3 turnovers before the engine fires up. Is this normal? In my previous car (mitsubishi legnum) it fired up practically instantly.
I have replaced the battery and had the alternator checked and all is ok there, so could it be starter/leads/plugs?
Any ideas?
Cheers
clossie
14-03-2018, 11:35 AM #1
Any ideas?
Cheers
14-03-2018, 11:45 AM
Wont be the leads as there is non, could be the plugs though
14-03-2018, 11:45 AM #2
clossie
14-03-2018, 11:49 AM
Thanks sparkystav, any chance it could be a throttle body in need of a clean?
The sparks have done 55k now so it's possible they are in need of replacement. Forgot bout the leads not being "leads" as such.
clossie
14-03-2018, 11:49 AM #3
14-03-2018, 12:40 PM
ever since i changed plugs to ngk iridium plugs it's taken 2 to 3 turns to start also changed the fuel pump a presure regulator so it may be that aswell
14-03-2018, 12:40 PM #4
clossie
14-03-2018, 09:43 PM
Thanks Jay will look into that. Re replacing plugs I was gonna stick with own denso's as most people recommend them. I have used ngk's before and was pleased wither them, however in this instance I will start with being a lemming
clossie
14-03-2018, 09:43 PM #5
clossie
15-03-2018, 11:48 PM
Ok have found a set of sk20's for £50 on sparkplugs.co.uk and will be ordering some shortly and hopefully fitting weekend after next. Does anyone know the torque I should apply when tightening down the new ones? I know it's not much.
clossie
15-03-2018, 11:48 PM #6
16-03-2018, 10:25 PM
Clossie i think your find the torgue setting to be about 13 ft-lbs
16-03-2018, 10:25 PM #7
clossie
16-03-2018, 10:33 PM
Thanks
clossie
16-03-2018, 10:33 PM #8
Thanks
BRANNERS
16-03-2018, 10:35 PM
I recon the best thing to start wiv is the plugs as they can cause all sorts of silly problems i struggled to get past 145 in the skyline but changed the plugs for a colder rated plug went with ngk and was happy when i flew past 160 lol. Does the car have coil packs as they are a ***** too when they break down?
BRANNERS
16-03-2018, 10:35 PM #9
16-03-2018, 11:00 PM
Yes the car does have coil packs and they can some times go
16-03-2018, 11:00 PM #10
Views 457
05-12-2018, 02:04 AM
Last Post by bobba77
Views 923
20-08-2018, 11:36 AM
Replies 24
Views 1,194
07-10-2017, 06:29 AM
Last Post by reganlives
