Plastidip
Plastidip
Is this purely to protect them Ian?
PS Your link has an extra http in it...
Lexusboy I am thinking of using Plastidip on my rear badges.
Has anyone tried using this yet?
Click me
Click me
Here a vid on how to use Plasti dip
http://youtu.be/SP8owpbR1iw
You can colour code your emblems grill and even your wheels with this stuff
The items your need to do this is the following
Materials
1. Can of PlastiDip
2. Small plastic pick/spackle thing.
3. Masking Tape
4. Newspaper
5. Rubbing Alcohol, Soap, water
6. Cotton Swabs
7. Clean Towels
Dave no this is so you can change the colour of your emblems.
How to use mask of a area around say a emblem with newspaper and tape you dont need to be up against the emblem as this stuff does not stick to you car paint,
Apply around three coats of your colour letting it dry fully between coats and don not over spray.
Once your item has been finished and is tootal dry just peel off the plasti dip from your paint work.
Questions : can i take it off if i dont like it or want to change colour
Answer is yes just peel back the plasti dip and start again.
Always make sure your clean your work surface before starting ideally with Alcoho and a few cotton buds to get tight into the corners
how can you leave your emblem on, as when you spray it will form a skin, if you peel it off the paint it will then peel off completely, emblem coverage as well,
If you look on a few plastidip removal vids it comes off as one piece,
even in his tutorial vid he emphasises it will all peel off @ 5.06,, so be careful.
Removal, it comes off as a skin,,
http://www.youtube.com/watch?v=HLsu6TQPv...re=related
