JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications HKS SSQV3 problem?
HKS SSQV3 problem?
HKS SSQV3 problem?
posty
28-03-2018, 12:47 PM
Fitted my ssqv today and it's not doing anything? No noise, bothing! Pretty sure it's all installed correctly (as per instructions)
Would there be a reason it's not working? Am I not running high enough boost levels for it to work?
Any help would be great
posty
28-03-2018, 12:47 PM #1
28-03-2018, 12:49 PM
With the charger?
you have to boot it to fairly high revs for it to do anything, or block off the bypass on the charger instead
28-03-2018, 12:49 PM #2
With the charger?
28-03-2018, 12:58 PM
can you post some pics up....have you tryd opening the bonnet and reving it while under your bonnet and seeing what happens?
28-03-2018, 12:58 PM #3
posty
28-03-2018, 01:12 PM
I'll have to take pics in the morning and post them up I forgot to take some before it got dark.
I tried that Ormi and it just didn't do anything the valve at the front stayed still. I expected it to move backwards.
posty
28-03-2018, 01:12 PM #4
28-03-2018, 01:51 PM
if you go to you tube and type in mr2driv3r you will see a video of mine dumping
28-03-2018, 01:51 PM #5
Phil01
28-03-2018, 01:57 PM
Have you got a short shifter on the lex marc??, revs cleanly
Phil01
28-03-2018, 01:57 PM #6
28-03-2018, 02:16 PM
Mines really loud, try building the boost up slowly and see if it dumps as you change gear, mine does it all the time and every gear change, and can be heard well over the top of the charger?
28-03-2018, 02:16 PM #7
28-03-2018, 03:07 PM
Phil01 Have you got a short shifter on the lex marc??, revs cleanly
No mate but was always thinking about gettin and fitting one just to see what sort of a diff it makes..
28-03-2018, 03:07 PM #8
Views 812
05-04-2023, 10:22 PM
Last Post by Millo73
Views 577
09-08-2021, 10:35 PM
Last Post by Jimbob-T-Lex
Views 219
07-03-2020, 12:49 PM
Replies 29
Views 1,425
25-12-2017, 08:05 AM
