Is200 speakers - front and rear
hey all.
after extensive research, I have found out that Corsa B speaker brackets will fit the Is200.
What I want to know is, where I can get off-the-shelf MDF adaptors as I do not have the time, space or proper tools to make my own.
also, with the rears, I will be fitting JBL 6 x 9's, with the frequency adjusted to 100hz. In your experience, will 12mm speaker rings be enough, or should I use 18mm. I only want to take it apart once, again due to my very little free time.
Cheers/
J
you can find plenty on Ebay J ranging in depth
for the front door speakers i used the standard brackets and they held my new speakers fine check out my build thread as theres pics in there
I had the VIBE SEK69's in the back of mine mate which are pretty deep, and i only used 12mm mdf for the mounts, and they were fine with clearance of the boot springs :thumbup1: i made my own though and not seen any available for the is200/300's off the shelf?
There are loads of mdf mounts on Us eBay.
As for the fronts, thats how I fitted the speakers on my Gen 7 Celica, but was hoping to do a better job on the Lex.
J
FunkMasterJay after extensive research, I have found out that Corsa B speaker brackets will fit the Is200.
FunkMasterJay There are loads of mdf mounts on Us eBay.
I there any drilling / special fasteners required to fit aftermarket 6 x 9s. I just want to be as prepared as possible. lol
Right, I set about installing the components today.
All installed, but for some strange reason the signal can't get past my MB Quart crossover to the woofer or tweeters, and if connected directly to test, they don't work unless the OEM tweeters are in place.
Eventually I don't know what happened but one brand new woofer stopped working. I give up.
I will just run a new set of wires throughout the car.
Will post pics later as my Blackberry is also on the blink.
A waste of a day off.
