JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications TIP: fix your leaking supercharger
rob
08-04-2018, 12:23 AM
After some years of operation you might have signs of an oil leak from the pulley area.
2 causes, the oil seal is worn or more serious the oil seal has worn a groove in the shaft and oil is now able to bypass the oil seal.
Split the unit and remove the front cover, inspect the shaft for any grooves etc. Replace the oil seal with a Viton double lip seal if possible
internal bore: 0.620
external: 1.120
width: standard .250
BUT if the shaft is worn use following widths to move the sealing lips away from the damage.
1st oversize: .310
2nd oversize: .370
its an imperial seal so all sizes in decimal imperial.
i have suggested viton double lip so even if 1 lip if on or near the damage the other lip should still seal.
viton is also a softer, longer lasting material and does not have the knife edge seal of the typical nitrile seals.
rob
08-04-2018, 12:23 AM #1
external: 1.120
1st oversize: .310
2nd oversize: .370
Phil01
08-04-2018, 03:58 AM
Good info Rob
Phil01
08-04-2018, 03:58 AM #2
Good info Rob
rob
21-07-2018, 01:01 AM
just a quick update.... if you order a "double lip" seal make sure it is a true double lip, some companies sell seals as double lip but they are actually a single lip with a wiper ring.
over and out.
rob
21-07-2018, 01:01 AM #3
over and out.
Views 1,908
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 824
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 513
06-04-2023, 02:00 AM
Replies 24
Views 1,226
12-01-2023, 11:53 AM
Views 177
03-01-2023, 01:19 PM
Views 135
27-12-2022, 10:58 PM
Views 471
02-12-2022, 01:57 PM
Views 483
04-11-2022, 05:54 AM
Views 85
30-07-2022, 01:49 PM
