how to stick number plates
Ok I have tried the double sided sticky tape from Halfords to stick on my number plate , but they dont work so good.
so dose anyone know of something better to use , and I'm not going to screw them on !!
Well the ones I got were the 1mm ones and the 6mm ones are just to thick .
Not used it on license plates but I've always found the double sided foam tape from B&Q quite strong!
Is this what you used?
http://www.halfords.com/webapp/wcs/store...Bid=t#dtab
parthiban Is this what you used?
Well I went for the stuff you linked to and think it might just work ^^^^^
Moley Well I went for the stuff you linked to and think it might just work ^^^^^
