JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Speedo problem
Speedo problem
Speedo problem
spud1973
19-04-2018, 09:23 AM
Ok here we go I did the clutch on my is200 and now have no speedo checked all the wires to the box and they are all connected. Any ideas guys as my tomtom cant keep up lol.:thumbup:
spud1973
19-04-2018, 09:23 AM #1
19-04-2018, 09:59 AM
Check everywhere round the box and the gear stick for trapped wires because this happened to Jay and his speedo didn't work after his wire(s) got caught.
19-04-2018, 09:59 AM #2
spud1973
19-04-2018, 10:30 AM
Will check that at the weekend did trap a wire between the bellhousing and back of the block but freed it up. Hmm will have to have a looksey again.
Cheers bud:biggrin:
spud1973
19-04-2018, 10:30 AM #3
Cheers bud:biggrin:
19-04-2018, 10:32 AM
Youve prob crushed the wire, best to unwrap the sheathing on it and have a look
19-04-2018, 10:32 AM #4
spud1973
19-04-2018, 10:39 AM
Will I be able to repair it or will I have to buy the loom and transducer??
spud1973
19-04-2018, 10:39 AM #5
19-04-2018, 12:00 PM
depends, you may be able to solder the wires back together if you have
19-04-2018, 12:00 PM #6
spud1973
22-04-2018, 08:13 AM
And now I have another problem I have got oil leaking from the back of the gearbox where the prop goes in. Is there a seal?? Or have I not pushed it in far enough??
spud1973
22-04-2018, 08:13 AM #7
22-04-2018, 08:19 AM
There is a little oil seal where the prop goes in mate, Wozza had this same problem which it was wearing, may need to get a new seal?
22-04-2018, 08:19 AM #8
spud1973
22-04-2018, 08:21 AM
Cheers bud will have to phone lexus tomorrow and order it:thumbup1:
spud1973
22-04-2018, 08:21 AM #9
22-04-2018, 10:07 AM
better not to solder it but to replace the part of the wire that was clamped with a new piece and use some crips on it, solder does have it's drawbacks when you are doinf´g the silver tin wire. and yes i did the same. easy mistake to make, anybody doing a clutch change i say remove to wires and pull them up into the engine bay out the way and then fit them after the clutch is fitted
22-04-2018, 10:07 AM #10
Views 452
18-10-2021, 01:45 AM
Views 138
12-05-2020, 03:26 AM
Last Post by Ji123
Views 434
02-11-2016, 10:07 AM
Last Post by aaronabbott
