Black Glossy Di-Noc Interior
Whilst surfing the US IS websites I saw a few had used Di-Noc on their interiors and quite liked the different look to the OEM wood/plastic that we have. I looked around on Ebay and found that other than the bog standard Di-Noc, they now do loads of different colours, including Glossy Black. So I took the plunge and bought some, below is how I got on:
First I took the rear door wood/plastic parts off, I thought I'd try doing these first so I could get to grips with this Di-Noc material. To remove the trim I used a sharp levering tool with masking tape wrapped around the tip. As it turned out you don't need to use that much force at all the lift the parts away from the doors.
Rear door parts:
And stripped out, 3 screws and a couple of tabs, clean the parts well:
Di-Noc applied and parts refitted:
Back in the rear door:
Then I thought I might as well do the fronts whilst I was at it. Here is the tool I used to help pry up the trim:
Stripped, cleaned and ready for the Di-Noc:
Drivers side re-fitted:
Passenger side:
Centre console was easy to remove, you can do it by hand and only 2 small electric connectors:
Nearly complete:
Re-fitted console and ashtray:
Now it's all been re-fitted and I do like the look of it, obviously I'd prefer a proper Carbon Fibre interior but finding something for a Right Hand Drive car is impossible.
Not sure if I will keep the centre console wrapped as there are 1 or 2 bits not right (did I mention I hate this Di-Noc, it sticks to itself and is a ****** to use), but will definately keep the door trims.......and guess that is the beauty of this product, you get fed up with it then you just remove it.
Keith
million times better than the wood effect :thumbup1:
Looks a load better than the wood effect :thumbup:
Cheers guys, I'm just like the rest of us I guess, a perfectionist, so any slight imperfections really bug me:glare: This stuff is great if you have a nice easy surface to cover where you dont need to see any sides/ends, which for example you don't see on the large section of the centre console. I'm sure if you work with this stuff you could probably cover anything.......and there's the rub, we don't work with it.
As I said I'm not too sure about the centre console, the small flip lid to be more accurate and the ash tray cover. However, after taking all this apart and realising that it really is very simple, then maybe spraying it is another option to take for those who don't like the wood/plastic and can't get CF in RH drive?
Keith
Well that didn't last very long. The car was parked in the sun and got hot inside causing the Di-Noc to lift on the edges of the flip lid.......so I stripped it off the console this morning.
However, I had a small strip left and thought I'd see what it looked like on a bit more of the console trim, see pics:
Keith
It looks good on its own but for me carbon fibre just doesn't go well with the wood next to it - is it expensive/possible to swap those pieces with the black wood finish that came in the later cars?
Quote:As I said I'm not too sure about the centre console, the small flip lid to be more accurate and the ash tray cover. However, after taking all this apart and realising that it really is very simple, then maybe spraying it is another option to take for those who don't like the wood/plastic and can't get CF in RH drive?
Tango If it had turned out OK I would have liked to skin all the silver CF with black, but by chance came across this on the net http://www.e90post.com/forums/showthread.php?t=499960
Don't think I'm willing to risk ruining the original parts:thumbdown:
