JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security RPM /TPS cables under dash?
25-04-2018, 09:19 AM
Quick Q guys as I'm on the last leg of my Zeitronix ZT-2 install.
Where can I pick up RPM / TPS sensor cables from underneath the dashboard? I know I can pick them up from the ECU box as I've already got them tapped from when I had my SAFC installed, but I'm assuming that they will both also be present underneath the dash somewhere too?
25-04-2018, 09:19 AM #1
25-04-2018, 09:31 AM
TPS im not so sure on
RPM from the OBD connection
25-04-2018, 09:31 AM #2
25-04-2018, 09:35 AM
Ahh so the OBD isn't all digitised then? I assumed it was all converted into a digital signal or something rather than just throwing the raw data straight out of the obd?
In that case If I can get RPM from OBD, I should also be able to get TPS and also water temp from there as well? As both of those are available on my Scangauge thats plugged in there at the mo?
25-04-2018, 09:35 AM #3
25-04-2018, 09:38 AM
as afar as im aware you can get the RPM from there as thats where my alarm is tapped into...
25-04-2018, 09:38 AM #4
25-04-2018, 12:34 PM
The rpm is the black cable on the obd on one corner, the rest from the ECU im afriad
25-04-2018, 12:34 PM #5
Views 920
16-01-2019, 02:31 AM
Views 644
29-07-2017, 04:15 AM
Last Post by Duv
Views 567
03-06-2017, 10:30 AM
Last Post by TM
Replies 18
Views 1,976
24-02-2017, 01:55 AM
