1994 MR2 GT-S in Caribbean Blue
Here for sale is my MR2 MK2 Turbo GT-S in Caribbean Blue. It's a 1994 car, so 'L' reg and is a tintop. The car is HPI clear (no finance on it and it's never been any category of write off).
Odometer currently reads 88,000 miles. Car was MOTd in November (passed first time with a few advisories which I sorted out) and has just had 6 months tax stuck on it (start of June). It passes MOT tests just fine with no CAT due to its age (no need for a 'friendly' MOT tester).
This car has always served me well, never broken down and has taken me and a passenger to Le Mans 4 years in a row without complaint. It is reliable enough to be my daily driver and only car, as you would expect from a sorted MR2.
The car has 2 keys (one original and one copy) and 2 alarm fobs. I have the pin code for the alarm and thatcham certificate.
Current Spec
As taken from the Pacific Works feature:
http://www.pacific-works.co.uk/car-profi...p?car=toxo and updated a bit
Engine:
ST205 Chargecooler conversion (as documented here: http://www.imoc.co.uk/forums/viewtopic.php?t=103914 )
ST205 ECU (engine warning lights for chargecooler system and a proven 15bhp power increase + safer fuelling)
Fujitsubo Legalis-R exhaust
Longlife custom 3" stainless midpipe (lifetime warranty on the work transferrable to new owner)
Hayward & Scott flexi pipe
Ceramic coated Blitz cast decat pipe (will NEVER crack)
Ceramic coated turbo elbow
Ceramic coated exhaust manifold
CT20b turbo rebuilt with steel parts, new bearings and seals
Ceramic coated exhaust housing
Polished compressor housing
Gizzmo Phenolic intake spacer
APEXI Super Power intake
HKS SSQV dumpvalve
SFS/Pacific Works intake hose set
GTech fan kit using 2 SPAL fans
SPAL PWM V3 fan controller (variably controls spal fan speeds based on water temp)
TRD Oil cap \/
Stef Derner clamping speedo converter and delimiter
New uprated 130A alternator in last 5000 miles
New Halfords high capacity battery in last 7500 miles (still has 2 yrs warranty)
Transmission:
E153 LSD gearbox
TRD torque mounts supplied by Fensport
Fidanza Lightweight Flywheel supplied by Century Motorsport
ARP Flywheel Bolts
Goodridge braided clutch hose supplied by bobhatton
Speedsource shifter bearings and base bushes supplied by sbits
Suspension:
Rev1 rebuildable struts
Koni adjustable inserts
TRD top mounts
Eibach springs
All supplied and fitted by Century Motorsport and aligned by Wheels In Motion
Fully polybushed using Prothane polybushes (inc ARBs, as per http://www.imoc.co.uk/forums/viewtopic.php?t=146258 )
Cusco front tension arms and camber adjustment bolts, making the suspension more adjustable
Exterior:
Border style front bumper supplied by Pacific Works
TOMs style sideskirts supplied by JeffD
Genuine Airwalker rear bumper
Raybrig headlamps
96+ clear sidelights
96+ heated retracting mirrors (these are a combination of 96+ UK spec glass and JDM retracting mirrors)
MR2 roadster 'eagle' badge
4-brake light rear conversion, rear fog using a Toyota UKDM rear fog light switch with the UK rear fog indicator in the instrument cluster (i.e. all looks factory)
UK front numberplate mount to maximise airflow to radiators
Brakes and Tyres:
Goodridge braided hoses supplied by bobhatton
Fully refurbished rear OEM brake calipers supplied by Brakes International
Completely rebuilt all the brake sliders and boots and carriers etc with new parts from Toyota, this cars brakes will not stick or jam for years and years to come
Genuine Toyota discs & pads all round (all shims, clips and springs present)
Cusco brake master cylinder stopper
Yokohama Super Advan SA3 16" split rims
20mm hubcentric wheel spacers on the fronts
Falken ZE912 205/45/16 on the fronts
Toyo T1R 225/45/16 on the rears
Rolled rear arches
Interior:
Omori 45mm boost gauge installed in stock location
TRD/Recaro replica heated reclining seats
Black headlining / sun visors
HKS CAMP engine monitoring system
HKS CAMP junction box
HKS CAMP boost pressure sensor
HKS CAMP temperature sensor
TOMs Steering Wheel
TRD gearknob
Rhon leather gearstick and handbrake gaitors
Stainless Steel Dial Rings
Working ice cold air conditioning (uses the newer gas)
Toad Ai606 Thatcham Category 1 alarm
Toad alarm 'security' LED moved into OEM position in instrument cluster (as per http://www.imoc.co.uk/forums/viewtopic.php?t=128031 )
Falcon total closure module (as per http://www.imoc.co.uk/forums/viewtopic.php?t=121197 )
Falcon electronic boot release (can open boot from alarm fob without disarming rest of car)
Audio:
Directed Viper 1200+ monoblock amp with dash control
Soundstream Rubicon 150 amp
Soundstream Power Station distribution
Soundstream 2 Farad power cap
Above all installed in frunk on an easily-removeable amp board, which has additional wiring present so you can remove the amps (spare wheel access, battery access, storage space for holiday) and still use the stereo.
Kenwood DNX-7200 double din touchscreen satnav
Kenwood KCA-BT200 bluetooth hands free module
Focal components
2 x Vibe 10" subwoofers
Reversing camera :lol:
Other Junk:
Has original JDM flare in passenger footwell and most of the original Toyota toolkit. Also has original Toyota optional boot mat and 'Man in Dandism' floormats, all as they were when the car was imported. Space saver spare wheel.
Car has NO ABS, NO AIRBAGS, NO TRACTION/CRUISE CONTROL.
The car has an extra (4th!!) fusebox in the boot, securely housing the electrics for the boot release, chargecooler pump, fan kit and rear foglights.
Currently dyno'd at 284bhp at stock boost at Surrey Rolling Road.
Photos
There are loads of photos of this car on the forum - I've used it to write guides on fitting the chargecooler, polybushes, total closure and other bits and bobs. Where I can find the write ups I've linked to them, so you can see plenty of pictures. Here are a few of the best:
(Current setup is the black line on the dyno output)
After the recent bodyshop work to the front end:
I also have the front foglights (non steering, mounting tabs intact) which were removed to make way for the border front bumper. These are fitted with a £60 set of PIAA bulbs.
History
Imported for me by Tom Solan at Northampton Vehicle Imports in 2006 - see http://www.nvicars.co.uk/ - a reputable importer of MR2s and an affiliate on IMOC. I am the only UK owner (although I think for importing purposes NVI might be listed as an owner). The car had all conversion work required for the SVA carried out by NVI and was converted to MPH at the same time. It was supplied on-the-road, with a full MOT and 6 months tax. When I purchased the car it had covered 53,000 miles. The car was then garaged for a year before I could afford to insure it and use it on the road :oops:
Most cars of this age have a varied history and this one is no exception - it has had a few scrapes! I discovered that it's definitely had some repair work done to it in Japan prior to being imported. However this was done to a very high standard and is nothing to be concerned about. The car's also been in the middle of a 3-car shunt on the M1 - again, repaired to a high standard this time at the bodyshop of my choice. Over £1500 was spent on the car at this time and I have the receipts to prove it in the service history. It does still have some superficial sill damage underneath one of the skirts - both myself and the bodyshop didn't deem this significant enough to warrant cutting the sill to pieces as it hasn't even pierced the paintwork.
The car spent a few months off the road last year, while I got the turbo rebuilt, and the exhaust parts ceramic coated. When it was reassembled it transpired that some rust had fallen from the exhaust manifold into the head and the valves wouldn't seal anymore due to the damage. The head was rebuilt by Pacific Works and the car reassembled. All gaskets in the intake and exhaust system were replaced during this period with new, genuine Toyota parts, and the Hose From Hell was replaced. A Gizzmo phenolic spacer was installed in place of the inlet manifold gasket, to reduce intake charge temps. The injectors were ultrasonically cleaned. The next time I changed the oil on the car I found some swarf in the oil, so I got Rogue (who have now moved quite close to me!) to whip the bottom end apart and check for any damage. The engine came back with a clean bill of health after an oil pump rebuild and has been faultless ever since.
To give you some kind of idea into the way this car has been treated and the money I spend on looking after it, off the top of my head the car has had:
New Toyota sidelights - old ones were mouldy (Jun 2011, £100)
New ignition coil, rotor arm, spark plugs, oil, oil filter, fuel filter all genuine Toyota (Jun 2011)
New coolant filler neck and radiator cap (Jun 2011)
New front ARB droplinks (Jun 2011, me, £60)
Bodyshop paint correction and tidying up the front bumper, and 2 years worth of stone chips / car park dings (Jun 2011, £625)
SPAL fan controller (May 2011, £110)
New wheel bearing (genuine Toyota kit) and wheel alignment performed by WIM (May 2011, £200)
New stainless midpipe made by Longlife Exhausts to replace rotting mild steel Fujitsubo one (May 2011, £246)
Front suspension arms replaced with new genuine Toyota & Cusco adjustable parts (Apr 2011, £850)
Coolant flush with Toyota Longlife and new genuine Toyota thermostat and gasket (Apr 2011, me)
Kenwood KCA-BT200 bluetooth interface fitted (Apr 2011, me, £90)
Uprated 130A alternator from the USA (Apr 2011, me, £150)
Engine bearings and head inspection, oil flush, new oil + filter etc (March 2011, Rogue Motorsport, £500)
Stef Speedo delimiter installed (March 2011, me, £70)
Oil changed again (+ filter, genuine, Jan 2011)
Complete head rebuild incl acid dip, new seals, pressure test etc and reassembly of engine with newly rebuilt/coated exhausts parts (Nov 2010, Pacific Works, £950) **HFH replaced at this point
Turbo rebuilt by bobhatton and balanced by Universal Turbos (Oct 2010, £300)
Turbo compressor housing polished
Turbo housing, exhaust manifold, turbo elbow and blitz decat ceramic coated (Sep 2010, Zircotec, £350)
Oil + filter, rotor arm, dizzy cap changed, genuine parts (June 2010, me, unknown mileage)
Kenwood stereo fitted (£350, early 2010, me)
New Apexi induction kit filter element (early 2010, me)
New genuine Toyota brake master cylinder (£250, Dec 2009, fitted by me)
DOT5.1 brake fluid flush (as above)
New genuine Toyota ECU water temp sensor (as above)
New genuine Toyota distributor cap (Late 2009 on 72000 miles, fitted by me)
New genuine Toyota rotor arm (as above)
New genuine Toyota HT leads incl. king lead (as above)
New NGK grade 7 spark plugs (as above)
Brakes International refurbished rear brake calipers (as above)
New genuine Toyota rear discs (as above)
New genuine Toyota rear pads (as above)
New Goodridge braided brake hoses (as above)
New genuine Toyota oil pump (late 2009 on 72000 miles, Pacific Works)
New genuine Toyota water pump (as above)
New genuine Toyota driveshaft seals (as above)
New genuine TRD engine torque mounts (as above)
Oil change for 5w40 Fuchs Silkolene Pro S (as above)
New genuine Toyota oil filter (as above)
Fidanza flywheel fitted with ARP flywheel bolts, clutch inspected with "plenty of life left" (as above)
Goodridge braided clutch hose fitted, clutch bled (as above)
Sump and strainer cleaned and refitted (as above)
Gearbox front torque mounting point reinforced (known weakness on E153 gearbox, as above)
Date to be confirmed but around mid 2009, exhaust midpipe flexi section replaced by Hayward and Scott, and additional work done to the mild steel elements of the exhaust by Pacific Works.
New Gates cambelt (May 2009 on 68000 miles, Pacific Works) Note that I was told the cambelt had been changed before importing, but wanted to be extra sure)
Oil change for 5w40 Fuchs Silkolene Pro S (May 2009 on 68000 miles, me)
Complete coolant flush using genuine Toyota LongLife coolant (as above)
Gearbox oil change to Redline MT-90 (as above)
An all important magnetic sump plug!
Early 2009 the car was detailed for a whole day by Ben (Tiny) who does 3S/TGT's detailing - results here: http://www.imoc.co.uk/forums/viewtopic.php?t=114531 This has had a lasting effect on the car and it looks stunning when polished with Autoglym HD Wax as I do. Since then the car's bodywork has been looked after by Towcester Coachworks whos work is excellent.
That's all I can remember for now without going back through the service history but it should be a clear indication that this car has been well looked after. The car has never been drag raced, taken on a track or taken round the 'ring. During my ownership it has always run 99RON fuel (admittedly Tesco's but fuel filters are cheap and there's nowhere else round here with super) and stock boost.
The car does have some small issues, it presently needs 2 new rear tyres which I will be fitting before August. There is a small crack in the rear bumper on the lip of the driver's side rear wheelarch, and some stone chipping to the passenger sideskirt. On the way back from Le Mans this week I picked up a chip in the windscreen - it's not big enough or in my line of sight enough to get the windscreen replaced, so it will be repaired instead.
In a nutshell, this is a well sorted rev3 turbo, with a proven history of being well serviced with genuine parts, producing excellent power at stock boost levels, with every common problem that occurs with MK2 MR2s already addressed. The hose from hell has been replaced, the brake sliders and rear calipers are new, the alternator is new, the droplinks are new, the suspension bushes are new, the ignition coil is new, the turbo seals and valve stem seals are new. There is no rust around the sills or the chassis rails anywhere on the car, even the 'cancer bars' look like new.
I am asking £4000 for the car. It is not 'priced to sell', it is priced at what I value it at. If it doesn't sell it's no skin off my nose
Additionally the car will be present at Duderstadt this year where it can be purchased for €5000 - this includes a bit extra to cover me getting home from Germany without a car!
Please note: This car is not available for collection until the 1st of August. You can come and view, test drive with appropriate insurance, leave a deposit to secure the car prior to then, by arrangement.
This is a sad day John , can I ask why you getting rid of your car ?
I was just about to ask yuo about the sat nav maps we were on about , but I wont bother now :p
Hope you get it sold mate , but if you dont you will still have a nice car to drive about in
Should this not be in the vehicles for sale section?
'tis a great MR2!!! A lucky new owner shouldn't be hard to find.
