JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Standard head unit/ amp
James S
08-05-2018, 04:00 AM
What happens when you connect an aftermarket to the standard amp? Or could I connect the standard amp to the pre-outs on an aftermarket amp?
James S
08-05-2018, 04:00 AM #1
FunkMasterJay
08-05-2018, 07:41 AM
I deleted my amp altogether and just installed a bypass loom. I still have standard speakers with my Pioneer HU and they sound great...but not good enough in terms of clarity and definition.
FunkMasterJay
08-05-2018, 07:41 AM #2
08-05-2018, 07:45 AM
Integration with the standard amp is complicated, and should only really be attempted by someone very competent with auto electrics.
The basic options are:
A) run standard system.
B) aftermarket headunit, amp by-pass cable and standard speakers.
C) aftermarket headunit, amp by-pass cable and aftermarket speakers.
D) aftermarket headunit, aftermarket amp, aftermarket speakers.
All of the following are probably possible, but are not generally done, due to the way the system works, and complexity of the task would probably not be worth the hassle for the given results:
Running standard headunit with aftermarket amps.
Running aftermarket headunits with standard amp.
Running aftermarket speakers with standard amp.
Running standard speakers with aftermarket amp.
08-05-2018, 07:45 AM #3
FunkMasterJay
08-05-2018, 07:49 AM
I am going for option D. Just a matter of getting everything together so I can do the full job in one day.
FunkMasterJay
08-05-2018, 07:49 AM #4
James S
09-05-2018, 02:41 AM
Yeah, I have got a separate amp and aftermarket head unit, will get them fitted soon.
I was just wondering what happens if you plug an aftermarket unit in without the amp bypass cable?
James S
09-05-2018, 02:41 AM #5
edeath
09-05-2018, 02:50 AM
It does not work. The amp only works with the OEM head unit.
edeath
09-05-2018, 02:50 AM #6
09-05-2018, 02:54 AM
If you remove the OEM head unit you loose sat nav (if its installed).
There are dongles correct this annoyance but I am not sure who sells them now.
09-05-2018, 02:54 AM #7
09-05-2018, 06:33 AM
James S I was just wondering what happens if you plug an aftermarket unit in without the amp bypass cable?
eDeath is correct, there would be no sound whatsoever.
09-05-2018, 06:33 AM #8
James S
09-05-2018, 09:38 PM
O right, didnn't think there would be no sound at all.
Hmm.... and didn't think about the sat nav. If i'd have known that i wouldn't have bought a Navigator model, and hunted for a sport LOL! ****** typical!
Why are cars so god **** expensive to modify! All I want is some decent tunes in the car, and at the min I have to burn a cd everytime I get some new music. GRR!
James S
09-05-2018, 09:38 PM #9
09-05-2018, 11:07 PM
james we can get the Nav working without the factory radio connected, alternatively we could change your screen at the top to be a dvd output or car pc etc lol
09-05-2018, 11:07 PM #10
Views 626
20-05-2022, 02:02 AM
Last Post by reganlives
Views 828
29-04-2021, 08:30 AM
Replies 22
Views 1,799
13-05-2020, 06:41 AM
Last Post by iceman
Views 506
19-03-2020, 01:25 AM
Views 663
16-03-2020, 09:00 AM
Last Post by daz@likwidart
Views 1,203
21-02-2019, 08:52 AM
Last Post by el_gencer
Views 569
18-10-2018, 01:15 PM
Last Post by valo
Replies 29
Views 2,109
17-07-2018, 12:52 PM
Views 607
19-04-2018, 11:22 PM
