JapCarForum Trade Area Trade Archive Selling Archive Is200 Forged Short Motor
Pages (3): 1 2 3 Next
15-05-2018, 10:08 AM
Ok so its with a heavy heart i have decided to cap the work on the lexus so with this being said im selling the upgrades i had been building
this liksting is for the forged bottom end it was built and tested by IKE and is basically like new
it has the following
set of steel "H" section con rods. with forged pistons to suit the Toyota Lexus 1GFE IS200 engines. The rods come with bronze bushed small ends with 18mm pin size and are longer than std to enhance rod angle and torque output. Oil holes for piston cooling are incorporated as per std. ARP 2000 bolts are included as std. Pistons are forged aluminum with revised ring pack, piston pin offset and compression height to reduce piston noise and increase power from std factory design. Compression ratio is as per std. Pins are floating with wire clips rather than the std interference factory fit. Crown design differs from std to increase swirl for increased combustion efficiency.
The block has been Bored out from 75mm as standard to the 76mm it was stripped back and the oiled up the outside casing has been painted in black.
all new Toyota Bearings have been used throughout.
i will also include a set of ARP head studs for this engine.
Looking for around £2500
Rabs
15-05-2018, 10:08 AM #1
Rabs
15-05-2018, 10:24 AM
Whhyyyyyyy!!!!!
15-05-2018, 10:24 AM #2
Whhyyyyyyy!!!!!
15-05-2018, 10:26 AM
just cant justify the work now
15-05-2018, 10:26 AM #3
15-05-2018, 10:32 AM
BOOOOOOOO! DO it yourself! get your hands dirty with oil for once instead of with cable sheath lol
15-05-2018, 10:32 AM #4
15-05-2018, 10:43 AM
ha ha lol im not afraid of getting my hands dirtyConfusedhock:
15-05-2018, 10:43 AM #5
15-05-2018, 11:28 AM
this unit is capable of 500+bhp i will go back and check, the info we put together to go with my current setup would have seen me at easily 400BHP if not a tad more
Edited 23-07-2011, 03:34 PM by Rabster.
15-05-2018, 11:28 AM #6
11-06-2018, 06:00 AM
bump
11-06-2018, 06:00 AM #7
bump
11-06-2018, 07:48 AM
bump back Smile i hope you find a buyer for it mate, but you can let me know if you dontSmile how are the brakes going, have you had time to post them out to me ? like the new car Smile it's going to be a one off and sure it's going to be the best ever
11-06-2018, 07:48 AM #8
14-06-2018, 02:47 AM
Bump again can anyone that is able to list for sale else where do so for me maybe driftworks or dare i say it LOC and any other sites where this may go....
need this gone asap i want to get rid of any bits not needed ASAP
14-06-2018, 02:47 AM #9
14-06-2018, 03:40 AM
will put it on dw tonight mate, and loc
14-06-2018, 03:40 AM #10
Views 400
05-05-2023, 03:10 AM
Views 1,451
06-09-2021, 04:01 AM
Last Post by KdotjapIS
Views 1,842
02-09-2021, 03:05 PM
Replies 40
Views 2,124
20-09-2020, 01:12 AM
Last Post by ozzie b
Views 279
17-09-2020, 12:35 AM
Views 403
06-09-2020, 05:51 AM
Views 222
02-09-2020, 12:49 PM
Views 299
23-08-2020, 10:16 AM
