Beams Altezza engine
Hi i can get hold of a beams altezza engine on the cheap and was wondering how hard it is to put in is200 and does the is200 gearbox fit on to it? any other parts i might be needing would be a great help!
You may as well put a 1JZ in the work is surprisingly similar.
The question that first jumps to mind is, Why? There doesn't seem a lot of point dropping in an Altezza lump. It would be far easier and cheaper to put an IS200 interior in an Altezza... there you go, exact same car!
well starters altezza got more bhp and parts seem cheaper and easier to get hold of than is200 parts
jimbob150385 well starters altezza got more bhp and parts seem cheaper and easier to get hold of than is200 parts
Yeah, this is what I am planning at the min. Been looking for a couple of years at the best option for getting more power from as IS200, and to be honest the easist option is to buy a tezza or a 300 and swap my bits on to it. Both models have dropped loads in price recently. So waiting till my insurance to drop enough to afford one, and making sure I only buy bits for my current 200 that are interchangable. Then when I find the right one, and I can afford to insure it. Buy it swap all the bits over, and then flog on my old one. Defo the most cost effective way IMO.
The manual IS200 gearbox (J160) is identical with the Altezza mate. I believe engine installation will be easy. Harness wiring might be a bit difficult. Make sure you get an egine together with an ecu and harness.
dimis The manual IS200 gearbox (J160) is identical with the Altezza mate. I believe engine installation will be easy. Harness wiring might be a bit difficult. Make sure you get an egine together with an ecu and harness.
