JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Coilovers and equal ride height
Imi
01-06-2018, 12:20 AM
A question for those with coilovers, On my IS i have the BC Racing coilovers, have noticed that the ride height is not equal, drivers side front is slightly higher than the passenger front, and drivers side rear is lower than the passenger rear, (I noticed the same when i had the lowering springs on) :blink:
The coilovers were set to equal gap before they were put on, the question is how do i get equal height?, do i adjust the coilover gap to different height settings or adjust the spring tension adjuster to set equal height? how have you guys equal your ride height?
Coils were fitted by Charlesworth motors a while back..
Ta
Imi
01-06-2018, 12:20 AM #1
Ta
Imi
01-06-2018, 12:51 AM
Ta for letting me know Gord, let me know what he does, so i can do mine.. going to put some 15mm spacers on the rear so need set equal height first.. so i don't want the tyre damage..
Imi
01-06-2018, 12:51 AM #2
Could they need a little bit of time to settle down? I can't say that I had any problems with my BC's when I had them fitted by Elite, but then they did full alignment at the same time, so maybe they adjusted them accordingly.
01-06-2018, 12:51 AM #3
Imi
01-06-2018, 12:54 AM
been on the car for a good 5 months now.. but haven't driven car much and not paid too much attention to ride height, untill now..lol
The IS does actually sits lower on the driver side rear as standard..
Imi
01-06-2018, 12:54 AM #4
01-06-2018, 12:58 AM
Weird, you'd think it would be the other way considering that the fuel tank is more towards the passenger side. Unless of course it sits even with a full tank of fuel :p
01-06-2018, 12:58 AM #5
Imi
01-06-2018, 01:00 AM
I don't fill up the car, i just put it in £10 £20 when i need it, other than that car is parked up.. i get a lift in to work, as they are charging £700 for the year on site parking..lol
Imi
01-06-2018, 01:00 AM #6
02-06-2018, 03:00 PM
count the threads on the coil over..
start at the first thread at the bottom then count up to the locking nut lets say your drivers one is 15 threads and the passengers one is 20 threads that means you need to wind the locking nut up 5 threads job done now your car will be even..
02-06-2018, 03:00 PM #7
Imi
02-06-2018, 11:47 PM
I was waiting for Ormi's input Smile thanks, wanted to make sure that it's ok drive if the coilovers are set different heights, "only slightyly tho"
Going to sort it out over weekend hopefully, and get the spacers on, hoping to get photos up soon, just few things to finish up first..
P.S Ormi your car is hust tooooooooooooooooo SLYCK :drool:
Imi
02-06-2018, 11:47 PM #8
dj0nes
03-06-2018, 09:33 AM
Have you had four wheel alighnment since they've been added to the car as I am pretty sure that can effect the height of the car slightly.
dj0nes
03-06-2018, 09:33 AM #9
03-06-2018, 10:14 AM
since whats been added?if you mean the spacers they only affect the track of the car ie the wheels will stick out further but it wont affect anything else..
03-06-2018, 10:14 AM #10
Views 292
29-08-2020, 11:09 PM
Last Post by bounty`
Views 422
03-06-2019, 04:31 PM
Last Post by Ji123
Views 256
18-12-2018, 12:49 PM
Views 783
21-11-2018, 11:35 AM
Replies 24
Views 1,751
06-06-2018, 10:57 AM
Last Post by Jon
Replies 18
Views 1,092
14-11-2017, 08:01 AM
Last Post by CW Racing
Replies 29
Views 1,525
03-06-2017, 04:51 AM
Last Post by MacRS200
Views 551
13-04-2017, 05:25 AM
Last Post by garyskisplym
Views 341
26-12-2016, 01:43 PM
Last Post by ormi
Replies 38
Views 1,586
25-08-2016, 07:34 AM
