JapCarForum General Discussions The JCF Lounge Got my work cut out!
Pages (3): 1 2 3 Next
07-06-2018, 09:04 AM
[Image: l_alky.jpg]
This should be an interesting install for sure! What we have here is a rather high pressure pump with braided lines, A progressive controller for the pump with a box for making adjustments inside the car, a boost sensor for activation and lots of other odds and sods!
07-06-2018, 09:04 AM #1
[Image: l_alky.jpg]
07-06-2018, 11:37 AM
~Thats a fun challenge!
Would be interesting to see the results.
07-06-2018, 11:37 AM #2
07-06-2018, 11:41 AM
Aye, its quite a big kit to hide somewhere. Space is at a premium in my engine bay as it is!
I'm also going to need to get it properly tuned once i start spraying. Probably a good thing as I have a feeling I'm running flame-spittingly-rich at the moment.
Edited 19-07-2011, 09:15 PM by jimxms.
07-06-2018, 11:41 AM #3
07-06-2018, 11:45 AM
Marsdendean Get it mapped, last thing you want is it to go bang after you have spent all that hard earned cash!!
Aye. Though I did attract the attention of two females this evening while out driving.
They shouted "is it supposed to do that" when the exhaust popped, so not exactly "hi sexy", but never mind :p
07-06-2018, 11:45 AM #4
07-06-2018, 11:56 AM
get the battery relocated to the boot! voila more space!
07-06-2018, 11:56 AM #5
07-06-2018, 11:58 AM
Sparkystav get the battery relocated to the boot! voila more space!
Is it as simple as it sounds? hook some 0AWG wire up to the existing contacts, run the wire through the firewall, down the side of the car, into the boot. Voilla?
07-06-2018, 11:58 AM #6
07-06-2018, 12:11 PM
jimxms Is it as simple as it sounds? hook some 0AWG wire up to the existing contacts, run the wire through the firewall, down the side of the car, into the boot. Voilla?
Pretty much.
Im fitting one of these in the engine bay:
[Image: GE55-FIA-Battery-cut-off-1.jpg]
And putting a 120A ANL fuse near the battery though just incase:
[Image: ANL_250_side.gif]
07-06-2018, 12:11 PM #7
Pretty much.
07-06-2018, 12:13 PM
What on earth is that top thing? Some kind of kill switch for disconnecting the battery from the engine bay?
07-06-2018, 12:13 PM #8
07-06-2018, 12:48 PM
exactly that mate, its a fia approved one so when wired correctly will kill a running engine as well
07-06-2018, 12:48 PM #9
08-06-2018, 12:41 AM
I think it is only a matter of time before you will have no option but to boot your battery! The rate you are adding things to that bay.
I think it really is as easy as extending some wires. Though for safety you should fuse it correctly, as Stav says, and I would also have it somehow enclosed and vented to outside.
08-06-2018, 12:41 AM #10
Replies 47
Views 2,112
22-08-2018, 03:34 AM
Views 478
25-04-2018, 10:36 AM
Last Post by Adster
Views 319
08-07-2017, 09:05 PM
Replies 22
Views 902
18-05-2017, 02:33 PM
Last Post by dandydons
Views 823
04-12-2016, 12:28 AM
Last Post by TM
Views 716
03-09-2016, 11:30 AM
Views 406
24-08-2016, 01:06 AM
Last Post by Cous3
Views 235
18-08-2016, 09:16 PM
Views 1,142
30-07-2016, 09:44 AM
Last Post by Andy-R.
