JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Need some white fog light bulbs!
jomo
13-06-2019, 12:33 PM
I bought a set of white 6000k led fog light bulbs of ebay to match the HID's i'v already got fitted.
Spent he best part of 45 mins f@nnying around getting the fogs out, swapping bulbs and putting back to find that they were sh!t!!!
So what do you guys have in yours to get rid of the old style bulbs and bring it more up to date?
jomo
13-06-2019, 12:33 PM #1
13-06-2019, 12:44 PM
Ideally you want HIDs, but you will be looking at £30-40.
When I did mine before I just bought some random £5 a pair ones off the old bay of E and was more than happy with them. (Sorry if that's not actually much help!)
13-06-2019, 12:44 PM #2
13-06-2019, 04:11 PM
I've tried several types of 'HID Match' bulbs and none come close to being even white, let alone the tint of blue that my 6000Ks have. I've got LED's in my fogs and they are a perfect match, however I just use them as DRLs not fogs because the light output is so poor.
My fogs are the newer ones with sealed H3 bulbs, which look difficult to fit HIDs to, otherwise thats what I would have done if they were the older style.
Edited 25-07-2011, 07:57 PM by sprinter2012.
13-06-2019, 04:11 PM #3
Ally
14-06-2019, 03:08 AM
Get some JDM yellow bulbs :biggrin:
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
14-06-2019, 03:08 AM #4
14-06-2019, 05:38 AM
HID ones are pretty good. My ones are the same 9006 fitment as the dipped beam, but you can get H3 HIDs, what is the problem fitting them Sprinter?
Also, (kinda on topic!) how do you find HIDs in the full beams? As I was always advised against fitting them due to their slow (compared with normal bulbs) start up times.
14-06-2019, 05:38 AM #5
Phil01
14-06-2019, 06:24 AM
I found them terrible in my old 200, took ages to warm up and did not really find them any brighter or had any greater projection than some 100watt main beams.
But things might have improved in the last year,
Phil01
14-06-2019, 06:24 AM #6
jomo
14-06-2019, 06:38 AM
I love the HID's in my main beams, ok they need to warm up but its only a few sec's!
Dont want to fit HID's into the fogs think it a bit over kill for something ill use 2-3 times a year, but would like the whole white look from my lights.
Looks like i may have to get some XENON type bulbs after all!
jomo
14-06-2019, 06:38 AM #7
jomo
14-06-2019, 06:41 AM
Oh FYI Marsdendean, i dont drive with them on as side lights only used when it's foggy!
Got busted about 8 years ago for that and got a £30 fine, learn't my lesson!
jomo
14-06-2019, 06:41 AM #8
14-06-2019, 10:05 AM
Stoney HID ones are pretty good. My ones are the same 9006 fitment as the dipped beam, but you can get H3 HIDs, what is the problem fitting them Sprinter?
The problem is that with the H3 style, the wires go through a sealed connector on the side of the foglight unit. You can't use the existing wires because they are far too thin to take an HID start up voltage. So you'd have to cut the wires on the HIDs, poke them through, then re attach them inside the housing. Which would make changing the bulb a pain, and you'd have to make 100% sure they were sealed again or you'd get the same corrosion problem as the earlier ones.
However the 9006 type would be doddle to fit, just like the main/dipped ones.
And on that note, I have HID main beams fitted. First time you use them take about 10 seconds to reach full temp. Then everytime after that is almost instant. I've only got 35W in both main and dipped but the light output is fantastic! To the level where I'm nearly dazzling myself when driving past a shiny new reflective motorway sign near my house :p
14-06-2019, 10:05 AM #9
14-06-2019, 11:31 AM
Phil01 I found them terrible in my old 200, took ages to warm up and did not really find them any brighter or had any greater projection than some 100watt main beams.
Except 100watt bulbs are not road legal Phil. HIDs are.
14-06-2019, 11:31 AM #10
Views 973
25-06-2022, 02:02 PM
Views 578
14-03-2022, 09:04 AM
Last Post by TezzaJoe
Views 1,077
14-01-2022, 10:27 AM
Last Post by lex2oos
Views 591
16-09-2021, 02:09 PM
Views 730
30-07-2021, 06:24 AM
Last Post by Dinho
Views 630
29-03-2021, 04:28 AM
Last Post by James S
Views 939
10-03-2021, 05:05 PM
Views 500
10-03-2021, 02:04 PM
Last Post by Colin G
Views 421
22-10-2020, 09:02 PM
Last Post by Jk 200sx
Views 796
09-10-2020, 11:05 PM
Last Post by MrGash
