JapCarForum Trade Area Trade Archive Selling Archive FS: Alky Control Meth Injection Kit
15-06-2018, 11:11 PM
Morning guys,
I'm selling my Alky Control methanol injection kit as I also purchased an AEM one at the same time and I decided to install that one instead.
This kit differs from a lot of the rest on the market in that it is supplied with steel braided hoses, screw-in copper connectors and a progressive controller with a separate MAP sensor. If you don't fancy running a new vacuum line, it will also accept the input from an existing MAP sensor to trigger the controller.
The price of the kit new is $599 and my one is completely UNUSED. The only thing I've done is open a couple of the plastic bags and build the connectors so its even easier to install for the buyer.
Here is an extract from the manu's website:
KIT INCLUDES:
PAC Progressive controller
Modified pump (for methanol)
Inline filter assembly
Stainless braided hoses pre-assembled
Misting nozzle
Check valve
Custom tank fittings
Custom vented cap
Pump fittings
Pump mounting hardware
T-fitting
Harness, loom, Connectors and ties
2 Bar GM MAP sensor with regulator
(Controls application of methanol at a preset boost level)
Comes with install instructions and tuning tips
1 year parts/ labor warranty
[Image: Alky%20Kit%20Layout_250.jpg]
I originally wanted £220 for it, but I just want it to cover the cost of my supercharger rebuild kit, so I'll let it go for £200.
Its easy to install and a great way to insure your turbo/sc'd car against engine damage. I'm not sure if it will be of any use to N/A cars - but I've heard reports of it making 20-30bhp difference to some N/A motors in hot climates.
Large tanks of Meth are available on eBay for home delivery.
15-06-2018, 11:11 PM #1
Morning guys,
KIT INCLUDES:
Misting nozzle
Check valve
Custom vented cap
Pump fittings
T-fitting
Views 150
27-06-2020, 12:44 PM
Views 348
28-01-2020, 11:48 AM
Last Post by S
Views 317
10-09-2019, 12:31 PM
Views 475
06-12-2018, 11:51 AM
Views 270
04-10-2017, 08:12 AM
Last Post by Chri5
