JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications TTE Supercharger Install Help!
Pages (6): 1 2 3 4 5 6 Next
164
30-06-2018, 12:28 AM
Hi guys
so i have bought AJ's charger, being delivered tomorrow.
I have a few questions,
i have found a tte install guide but kinda basic anyone got more detailed guides?
in the guide it says to cut and hammer the heat shield into shape, would it not just be better to take it off?
Aj's blackbox went a year ago or somat so he got a dastek chip, the only thing is im not sure what wires in the ecu i need to splice or cut into, anyone else got one? are they any good, what are you guys using?
also i think i read somewhere the clutch fluid resovoir has to be moved or piped into the brake one, or its in the way of the air box, is this the case and how would it be done, or is there a air intake i can get or make up, ive seen a few people with them, not sure if its bought or made up, alto i guess its only a 135 or 180 bend and a straight pipe with a cone on the end as i have a greddy 1 and would like to use that if i dont use the tte air box.
Anyway when it comes tomorrow il give it a good sort out and lay it out in the garage ready for when im 100% and have everything to get it how i want.
lookatmybiceps
30-06-2018, 12:28 AM #1
Hi guys
30-06-2018, 12:42 AM
Are you installing the airbox or the induction kit? if the latter you dont need the adaptor.
as for the Chip, put up a pic of what it is when it lands but i can help with the wiring.
you can take the heat shield off but its there for a reason, you just cut it out with tin snips or a hacksaw
30-06-2018, 12:42 AM #2
30-06-2018, 12:45 AM
i removed the Dask unit its only got 4 wires
12v
Ground
Sensor in
Sensor out
very easy to wire back in im racking my brain to remember the colour of the sensor wire....
oh btw mate i have some Silicone hoses for the charger kit if your interested not a full set but most of them.....
30-06-2018, 12:45 AM #3
12v
Ground
Sensor in
Sensor out
30-06-2018, 12:53 AM
Bring the kit along to JAE and you'll have plenty tech support there... Just bring some currency (the drinkable liquid kind) and I'm sure you'll have all the help you need...
30-06-2018, 12:53 AM #4
30-06-2018, 12:55 AM
Rabster i removed the Dask unit its only got 4 wires
12v
Ground
Sensor in
Sensor out
Bandit's guide in the Workshop area to fitting a black box should identify the ECU wires required.
Rabs, I am after silicone hoses for charger kit... though must be blue!
30-06-2018, 12:55 AM #5
12v
Ground
Sensor in
Sensor out
30-06-2018, 01:01 AM
Mine are blue
30-06-2018, 01:01 AM #6
Mine are blue
30-06-2018, 01:04 AM
Sparkystav you can take the heat shield off but its there for a reason, you just cut it out with tin snips or a hacksaw
well i was guna get some exhaust heat wrap will that be ok i dont really want to mutilate the heat shied.
lookatmybiceps
30-06-2018, 01:04 AM #7
164
30-06-2018, 01:06 AM
DaveEdin Bring the kit along to JAE and you'll have plenty tech support there... Just bring some currency (the drinkable liquid kind) and I'm sure you'll have all the help you need...
would love to my mates goin he in the sxoc but im starting collage round about then so not going to be able to make it this year.
lookatmybiceps
30-06-2018, 01:06 AM #8
30-06-2018, 01:42 AM
Rabs, can you PM me which hoses you have and which you don't and we can probably do a deal. By the time JAE comes around you may have half your garage in a box for me!
As for the intake, I don't know if they can be bought anymore? But they can certainly be made up. It has been done, if you have a real good forum search you should find some details. But essentially, any combinations of silicone piping and/metal to connect the charger intake to a filter, usually placed directly behind the headlight, should do the trick!
Most people with black box failure use an HKS FCD, but one member has made a black box replacements, and is, I believe, making more for sale. (It's Patrick in Sweden, again have a search, probably in the IS200 Charged section of the forum for more details.) though if the previous owner of your kit had a solution that worked, you should be ok to run with that.
30-06-2018, 01:42 AM #9
30-06-2018, 01:45 AM
lookatmybiceps well i was guna get some exhaust heat wrap will that be ok i dont really want to mutilate the heat shied.
Would probably offer as much heat protection, though I'm not expert in these things. I don't think the heat shield mod should be too much of a problem for you to do though, and if you wish to return to stock at some point, a new one can be sourced from a scrappy, and a dare say a member or two on here would have an intact one laying around somewhere too!
30-06-2018, 01:45 AM #10
Views 1,892
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 808
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 512
06-04-2023, 02:00 AM
Replies 24
Views 1,188
12-01-2023, 11:53 AM
Views 176
03-01-2023, 01:19 PM
Views 132
27-12-2022, 10:58 PM
Views 467
02-12-2022, 01:57 PM
Views 481
04-11-2022, 05:54 AM
Views 84
30-07-2022, 01:49 PM
