JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications DIY Supercharger Issue
Pages (10): 1 2 3 4 510 Next
Jon
16-07-2018, 02:09 PM
Hey guys,
having a little problem, hopefully someone can help?
Ive done a DIY supercharger conversion on my IS200 - got an M62 supercharger from a merc SLK230, made my own cradle, decat manifold, HKS FCD, HKS SSQV BOV, Tims Boost Gauge, Merc SLK230 water pump pulley, PK5 788 belt, eBay intercooler and eBay pipes etc. Its only cost me about a quarter of what the TTE kit costs second hand so i'm happy!
Anyway, the problem I'm having, from cold its running fine - supercharger is switching the electronic clutch via a microswitch on the throttlebody and the power is there when needed. When the engine/engine bay gets warm, the engine 'splutters' at around 3k rpm - with and without the Supercharger engaged (via electronic clutch). The FCD is set to 10 at the moment ( I seem to have an early FCD which doesn't have any numbers on, so I can only assume it is set to 10)
I'm assuming (At The Moment) that the intake air is too warm, and the ECU is having a fit? Tomorrow Im am going to connect via OBD2 to see what the intake temperature is running at!. I'll report what I find. I havent got any heat sheilds on the exhaust manifold, but I have heat wrapped it. I will be putting a heat sheild on tomorrow to see if this helps.
If anyone else can think of any possible problems, please feel free to let me know. I needs to try and get these issues ironed out before Trax next weekend!
Jon
16-07-2018, 02:09 PM #1
Hey guys,
16-07-2018, 02:31 PM
May be a silly q but is the fcd working? Or wired in right?
Would seem to me to be the issue.
Ps what's the boost like? What boost does it run?
16-07-2018, 02:31 PM #2
16-07-2018, 02:32 PM
Wow thats sound like you put a lot of effort into to set up, ive got the TTE only had for a week so i dont really have any advice but would like to see some pics of your set up. altho i have heard the fcd can run lumpy at low rpm or something, someone will have more info.
lookatmybiceps
16-07-2018, 02:32 PM #3
16-07-2018, 02:35 PM
Yeah the fcd's aren't ideal to be honest. I think it's a legacy of 'they worked on x car so they will work on a, b, and c as well.
The greddy bcc is far better if a little rarer.
16-07-2018, 02:35 PM #4
Jon
Sparkystav May be a silly q but is the fcd working? Or wired in right?
I have wired the FCD as to what I have found on here and LOC
"The Red wire from the FCD just T's into the Black with red stripe
The Black wire from the FCD T's into the White wire with Black stripe
The Yellow wire goes towards the ecu to a Green wire with Red stripe, the green wire you have to cut!!
The White wire from the FCD goes away from the ecu to the other end of the Green wire with the Red stripe.."
Boost says its just above 0.2 bar (MAX), but the gauge sits at just below 0.0 bar when the engine is not running. I've got another gauge to try, but I am not sure how accurate it is
Jon
16-07-2018, 02:35 PM #5
Jon
16-07-2018, 02:38 PM
i forgot to add, I have a Camcon wired in, which doesnt seem to have any noticeable affect to the problem when its on or off!
When it ws N/A you could tell when it was on or off
Jon
16-07-2018, 02:38 PM #6
16-07-2018, 02:39 PM
All sounds right mate. Could be the fcd itself then maybe?
You could be best contacting patrik on here as he is making some tte black box replacements. I've got the diagram I made myself but never made one yet.
16-07-2018, 02:39 PM #7
16-07-2018, 02:40 PM
Is the camcon wired through the same wire I can't remember. May need adjusting now with extra boost.
16-07-2018, 02:40 PM #8
Jon
16-07-2018, 02:43 PM
i might take the FCD off my bros 200SX and see if that works? My FCD seems to be an older one, square metal case, rather than the newer plastic rounder case? i dont know if thats makes a difference
I still think it is the Intake temperature causing problems, but I wont know till tomorrow - or does this sound like a far fetched scenario?
Jon
16-07-2018, 02:43 PM #9
Jon
16-07-2018, 02:44 PM
Sparkystav Is the camcon wired through the same wire I can't remember. May need adjusting now with extra boost.
Different wires, I checked that.
Like I said, Camcon on or off, still does the same when warm(but runs ok when cold?)
Jon
16-07-2018, 02:44 PM #10
Views 1,893
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 816
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 513
06-04-2023, 02:00 AM
Replies 24
Views 1,192
12-01-2023, 11:53 AM
Views 176
03-01-2023, 01:19 PM
Views 133
27-12-2022, 10:58 PM
Views 468
02-12-2022, 01:57 PM
Views 482
04-11-2022, 05:54 AM
Views 84
30-07-2022, 01:49 PM
