JapCarForum Cars, Cars, Cars! Project Cars Who's been a busy boy then? My GT4!
Pages (3): 1 2 3 Next
mark3
23-07-2018, 01:47 AM
Woohoo, its not back here from its 10 month storage for one whole day & work has started, engine and box are out! Took about 5 hours inc getting it clear of the car.
[Image: 2011-08-30140504.jpg]
[Image: 2011-08-30141722.jpg]
[Image: 2011-08-30150655.jpg]
[Image: 2011-08-30153446.jpg]
tomorrow il be splitting the engine and box and fitting a very sexy OSgiken twin plate clutch i got last year, then prepping head and block surface for a 1.4mm Cometic mls head gasket thats going on with ARP studs & nuts
busy busy busy, lol
day two
We got the engine and box seperated today ready to install the OSgiken TS2B twin plate racing clutch, trouble is friction plate No 2 was really too worn to be reliable so a new plate has been ordered and @ £250 it means the cost of the clutch is £500 BUT it would be £1200 if new, the new plate will be here on Friday. im going to change the rear main seal too just in case
[Image: 2011-08-31153413.jpg]
[Image: 2011-08-31153446.jpg]
Just as well the new clutch includes a new flywheel as the old one was in a right state
[Image: 2011-08-31153500.jpg]
[Image: 2011-08-31160223.jpg]
OH and with the engine out i found the cause of my high idle problem that i coudnt iron out, some idiot at some time has bypassed the power steering idle up valve on the pas pump, the 2 vac hoses to the valve have been joined together so now it has a constant vac leak as opposed to only when you hit full lock.
Day three
I got the head off this morning and i was pleased to see NO CORROSION in the head coolant channels at all but good grief there all so blocked up I'm amazed it only overheated on boost lol
[Image: 2011-09-01084115.jpg]
[Image: 2011-09-01092139.jpg]
[Image: 2011-09-01092308.jpg]
[Image: 2011-09-01104017.jpg]
Then i took some measurement off the OS clutch plates just to see how worn No2 plate was
[Image: 2011-09-01121750.jpg]
Compared to No1 plate which is in very good condition
[Image: 2011-09-01121916.jpg]
This leaves me with just under 1.4mm of compression of the plate/s assembly so with the new plate in all should be fine and dandy.
[Image: 2011-09-01124026.jpg]
New plate should be here tomorrow and the Extremely pleasant people at RB racing from where its coming from are even sending me an old input shaft i can use as a clutch aligner. i tend to wrap tape round an extension and this has always worked very well as you Can get it the exact size BUT with twin plates are twin splines, and not only do the plates have to be centred the splines have to line up too.
Also have a new rear main crank shaft oil seal coming too.
It looks like the gearbox has been overhauled some time in its life as there is orange sealer visible at the many casing joints AND the oil was like new, very clean and golden in colour too, so thats a good thing lol
Oh and i been thinking, the fact the PAS idle up valve was bypassed would have given me a loss in boost as well as a vac leak!!
mark3
23-07-2018, 01:47 AM #1
busy busy busy, lol
day two
Day three
mark3
23-07-2018, 01:48 AM
Day four,
New clutch plate arrives early, woohoo!
[Image: 2011-09-02130102.jpg]
and at 4mm thick it proves my No1 plate at 3.6mm thick has plenty of life left on it, woohoo again.
New rear main oil seal
[Image: 2011-09-02134550.jpg]
OS giken flywheel on torqued to 85lbft
[Image: 2011-09-02135440.jpg]
Plate 1 in
[Image: 2011-09-02135508.jpg]
Centre plate in
[Image: 2011-09-02135519.jpg]
Plate 2 in
[Image: 2011-09-02135542.jpg]
Pressure plate in
[Image: 2011-09-02140001.jpg]
clutch cover on and bolted up through 4mm of spring compression
[Image: 2011-09-02141600.jpg]
And a huge thank you to the guys at RB motor sport who was kind enough to lend me there clutch aligner/input shaft.
[Image: 2011-09-02141628.jpg]
Gear box and engine back together.
[Image: 2011-09-02151731.jpg]
Then work on the block started and went on, and on, and on.... Big thank you to TRD who has the patience of many saints when it comes to doing this, thanks again buddy.
[Image: 2011-09-02151749.jpg]
5 hours later it looked like this! its as smooth as a smooth thing thats been smoothed over, finishing off with 1200 grit wet n dry for an hour using WD40 as a lubricant for a finer finish.
The black areas between coolant channels are not a worry as the head has large channels there and exert no pressure on the gasket at all in those areas.
[Image: 2011-09-02175144.jpg]
Then the head
[Image: 2011-09-02185830.jpg]
Got it stripped of cams and what not to lower all the valves
[Image: 2011-09-02185836.jpg]
And this is what we had to start with
[Image: 2011-09-02190134.jpg]
Finished it off in the dark so more pics tomorrow when i build it back up and then fit it to the block.
mark3
23-07-2018, 01:48 AM #2
Day four,
Plate 1 in
Centre plate in
Plate 2 in
Pressure plate in
Then the head
23-07-2018, 02:05 AM
Good work.
23-07-2018, 02:05 AM #3
Good work.
23-07-2018, 02:13 AM
Good work keep the thread running:thumbup1:
23-07-2018, 02:13 AM #4
mplavery
23-07-2018, 03:46 AM
Great work mate! As above...love these write ups.. Makes me want to rip my engine out lol
2nd BEST IN SHOW (JAE 2011)
3rd BEST MODIFIED (JAE 2011)
[/COLOR]
[/COLOR]
mplavery
23-07-2018, 03:46 AM #5
[/COLOR]
[/COLOR]
Phil01
23-07-2018, 04:05 AM
ST185,,Good work mate, nice to see another GT4, keep us updated
Edited 03-09-2011, 01:39 PM by Phil01.
Phil01
23-07-2018, 04:05 AM #6
speedfreek
23-07-2018, 06:44 AM
Loving this so far! Keep it up! Big Grin
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
23-07-2018, 06:44 AM #7
[/SIZE]
(Current project)
mark3
23-07-2018, 10:55 AM
Gord Nice one, love seeing people do all the work them selfs :kiltsmilie:
Keep the pics coming
Haha maybe i should add that i do it for a living, i am http://www.mobilemechanic.org
Anyway, onwards ever onwards lol
Day 5!
Fit head and get engine and box ready to install.
This is where we got to last night with the head
[Image: 2011-09-03125854.jpg]
Block ready to accept the head with Cometic 1.4mm mls gasket in place
[Image: 2011-09-03125833.jpg]
Head on, torqued down to 90lbft in 10lbft stages from 30lbft using ARP stud/nut and the supplied molly lube
[Image: 2011-09-03132047.jpg]
Cams going in
[Image: 2011-09-03143106.jpg]
Had a problem with the cam belt running to-wards the outer edge of the cam pulleys so i had no alternative but to remove the lower belt cover to see why it was doing this?
[Image: 2011-09-03163741.jpg]
After removing the timing belt tensioner and tensioner pulley, several times, and finding no apparent problem it eventually seemed to run ok in the middle of the cam pulleys, im not too keen on leaving things like this as there must had been something out of alignment but its ok now so i pressed on and refitted both covers and the crank pulley, and its just dam handy having the right tools for the job, my Crank holding tool coming in dam handy, lol
[Image: 2011-09-03170735.jpg]
[Image: 2011-09-03170729.jpg]
End result from day 5 is the engine and box are ready to put back in on Monday, im having tomorrow (Sunday) off, lol
mark3
23-07-2018, 10:55 AM #8
Day 5!
Cams going in
mark3
25-07-2018, 10:47 AM
Stevieboy Mark, your signature is out of date again. Confusednicker:
Not till Sunday, lol
Anyhow, Day 6 and the engine is in! :cheeky: Hoorah!
Started the day (well started at noon) by rebuilding the n/s inner CV that fell to bits on engine removal, all the balls fell into the gaiter!
****** rubics cube got nothing on these, lol, then after a shed load of grease fitted it back onto the drive shaft and bolted the flange back onto it to stop it from happening again.
[Image: 2011-09-05132406.jpg]
[Image: 2011-09-05135650.jpg]
Next up was getting the dam engine and box under the car, this took about 45 mins using the engine hoist to lift the gear box end and using a crow bar to move the sump across the ground at about 2" to 3" at a time.
[Image: 2011-09-05142935.jpg]
[Image: 2011-09-05144000.jpg]
[Image: 2011-09-05144657.jpg]
And hey presto, its in!!
[Image: 2011-09-05151615.jpg]
Then after a short break i cracked on and got all the cross members and engine mounts done, suspension and drive shafts in and bolted up, prop shaft on, exhaust on and wishbone support bolted on, gear lincages done, gear box oil cooler pipes done, fuel pipes done and clutch hydraulics done and bled, the clutch feels surprising light considering how heavy the spring in the clutch cover is.
[Image: 2011-09-05180633.jpg]
[Image: 2011-09-05180646.jpg]
[Image: 2011-09-05180734.jpg]
Weather is meant to be sh!te tomorrow but for now im well happy.
p.s. although this is actually quite possible to do by ones self i defo wouldnt recomend it :no: Big Grin
mark3
25-07-2018, 10:47 AM #9
25-07-2018, 11:11 AM
You make it look so quick n easy ... I shall start questioning my mechanic as to why it took longer than your twenty mins lol .. wtg you Smile
25-07-2018, 11:11 AM #10
