Horns/ hooters
Horns/ hooters
Anyone changed/relocated them ? with a sport grille its quite visible, easy to change/relocate ? i.e plug and play ? i saw some horns by 'sickspeed'
http://www.ebay.co.uk/itm/SICKSPEED-SUPE...4158d9fd03
and PIAA
http://www.ebay.co.uk/itm/PIAA-Dual-Tone...3a5c1ab240
OK still visible but it look better imo, either that or paint OEM ones red or just relocate, hmm what to do.....
not the kind of thread I thought it was going to be :confused1::thumbdown:
Moley not the kind of thread I thought it was going to be :confused1::thumbdown:
Ive extended the wires on mine and moved them right down to beside the tow eyes.
If you extend the wires you can put them anywhere.
I did read somewhere someone wasnt happy with the sound of original ones, i not have problem with it though, do i need to remove or extend wires just to lower it to bumper/crash bar level ?
again not what i wanted to see in this thread. what a disappointment. lol
I just fitted some new horns, still too high pitched for my liking so I'm going to get a set of the PIAA Low Tone (400/500Hz Version).
Moving them is extremely easy, just undo a couple of bolts to get them off.
The stock wiring has a spade connection for the positive and the horn itself earths to the chassis, and as most aftermarket horns have both a positive and negative terminal, you will need to make a wire that has a spade terminal on one end, and an M6 ring connector on the other end to earth the horns to the fixing points. I also made some small brackets to mount them on because the new horns only came with straight mounts so would have fouled the crash bar.
See below, the OEM horn, the mount the new ones came with and then the new horns with my custom mounts...
This interests me !
The Supra horns are so so Embarrassing ! Not aggressive at all, kinda sound you expect on a old mini or something or imp lol
Let me know what you choose and how you get on mate
