JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning changing bulb help
changing bulb help
changing bulb help
Pages (7): 1 2 3 4 57 Next
davidjamesbattersby
11-08-2018, 03:49 AM
im new here and have a 2000 is200 se, im wanting to change all my bulbs in the dash etc, can some one tell me how many of each bulb and what bulb to do the clocks, heater dials and clock, and also the heated seat switches, trc control and snow mode and also the rear fog switches and the ring around the ignition barrel, and any other bulb that can be changed with out soldering ie door switch cig lighter, can some one just tell me how many t3 and t5 i will need so i can order them, please help guys
davidjamesbattersby
11-08-2018, 03:49 AM #1
11-08-2018, 04:12 AM
:biggrin:
I think I answered this over on the "other side", but you will require soldering/messing about with the door switches, cig lighter, heater unit and heated seat switches IIRC.
The dash is 3xT10 and 2xT5, they're changed as per this link
Most of the other info you should be able to find here
11-08-2018, 04:12 AM #2
:biggrin:
davidjamesbattersby
11-08-2018, 04:36 AM
any one know a good supplier to buy the bulbs on there own, ie the ignition barrel bul etc
davidjamesbattersby
11-08-2018, 04:36 AM #3
11-08-2018, 09:18 AM
davidjamesbattersby any one know a good supplier to buy the bulbs on there own, ie the ignition barrel bul etc
I usually just have a good ebay search. SMD LED ones are the ones to go for, in the correct fitment, obviously. My dash currently has non-SMD LEDs and they are ok, but don't give the light output or spread of SMDs. Usually the cheapest are from the far east, but it's usually worth the wait for bulbs that are often under £1 each, and identical to the ones UK suppliers sell, sometimes at many times the price! Some (like red bulbs for my rear fogs) I can only find from Hong Kong!
11-08-2018, 09:18 AM #4
11-08-2018, 10:07 AM
The ignition barrel is a T5 so is the ash tray if that helps
11-08-2018, 10:07 AM #5
davidjamesbattersby
11-08-2018, 11:19 AM
thanks guys i have read that the heater controls arnt the type you have to solder, is this true
davidjamesbattersby
11-08-2018, 11:19 AM #6
11-08-2018, 11:23 AM
You are sort of right they don't have to be done like that but to get the best light output its better if they are.
I have used a set of bulbs that I got from the US but as I said the light output is really bad
11-08-2018, 11:23 AM #7
davidjamesbattersby
11-08-2018, 11:40 AM
is there any one soldering these kits still, i know jay from sweden was doing it from what i can see
davidjamesbattersby
11-08-2018, 11:40 AM #8
11-08-2018, 11:44 AM
I'm not sure if he's still doing it mate send him a PM and ask
11-08-2018, 11:44 AM #9
11-08-2018, 01:20 PM
yes still doing it but have been sick the last month and holidays before that. will be back on it soon Smile
11-08-2018, 01:20 PM #10
Views 515
23-05-2017, 03:28 PM
Last Post by todd
Views 207
24-12-2016, 11:50 AM
Last Post by Andy-R.
