JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Tow Bar Electrics
Tow Bar Electrics
Tow Bar Electrics
steviec_lj
23-08-2018, 02:03 AM
Hi guys,
After solving the lights issue a few months ago, I am now on with the next electrically minded part of the car.
Having got rid of the rust bucket vectra I had, I now need a tow bar on the IS200. Question is, will I be needing a 7 way bypass relay?
Answers on a postcard please.
Thanks,
Steve
steviec_lj
23-08-2018, 02:03 AM #1
Hi guys,
Thanks,
Steve
Phil01
23-08-2018, 09:02 AM
you will need to take your brake light fed on the input side of the lamp failure relay,
indicators should be ok as per normal
OR
wire up everything as normal without going thro any relay and then use LED lamps on the trailer.
What are you going to connect the blue wire to,,, Generally rear fog light as on some earlier caravans they used pin No2 (blue) as a 12v feed for battery charging etc
Edited 04-10-2011, 06:40 PM by Phil01.
Phil01
23-08-2018, 09:02 AM #2
OR
Views 424
09-03-2019, 10:34 AM
Last Post by is300_dino
