JapCarForum Car Manufacturers Lexus/Toyota Is a reversing camera a reversing camera a reversing camera?
08-09-2018, 05:01 AM
The reversing camera in my LS430 is on its way out and the picture is really blurred. I've taken the camera out and I can't see anything physically wrong with it so I'm assuming that it has become moisture damaged at some point.
Problem is, Lexus want silly money for a replacement (read: over a grand) and the breakers also know its value and are charging upwards of £200 for a new one. Here's the ******:
[Image: %24(KGrHqZ,!hIE5oeOInFJBO,rq935hQ~~60_12.JPG]
My question is, could i potentially hack a cheap ebay camera in its place and just wire it up to the oem harness?
Given that both cameras operate at same voltage and are PAL/NTSC or whatever. Is there anything else that might make them incompatible?
08-09-2018, 05:01 AM #1
08-09-2018, 05:27 AM
Jim i am sure if you make sure it running the same voltage and re connect the old connector it should work.
The camera's are only around 20-35 pounds so it worth trying anyway...
08-09-2018, 05:27 AM #2
08-09-2018, 05:32 AM
Certainly works in theory. Good ones can be had for under £20 too. (One of my next mods!)
08-09-2018, 05:32 AM #3
08-09-2018, 05:33 AM
Lexusboy Jim i am sure if you make sure it running the same voltage and re connect the old connector it should work.
Yeah exactly. I think I'll just buy one to give it a shot. If it doesn't work, I guess I'll have to look out of the back window instead when reversing :tongue_smilie:
08-09-2018, 05:33 AM #4
BOOSST
08-09-2018, 05:47 AM
I have a very lovely infa red reverseing camera on my MR2 and I can whole heartly say.....
It's a ruddy useless load of **** :thumbdown:
BOOSST
08-09-2018, 05:47 AM #5
08-09-2018, 05:50 AM
BOOSST It's a ruddy useless load of **** :thumbdown:
Awesome lol. Whats wrong with it?
This is what I had my eye on as a replacement as it seems vaguely similar in size, shape and mounting.
http://www.ebay.co.uk/itm/300587677837?s...1423.l2649
08-09-2018, 05:50 AM #6
08-09-2018, 05:56 AM
again you get what you pay for with ebay cameras i have a cheapy camera and its ok but as soon as the reverse lights are on at night i can hardly see naf all lol during the day its fine
in theory i see no reason why it wouldnt work have you tried connecting the camera to your tv at home make sure it is only the camera thats naffed up not the cars part....
08-09-2018, 05:56 AM #7
BOOSST
08-09-2018, 05:58 AM
jimxms Awesome lol. Whats wrong with it?
On a bright sunny day and clean roads, nothing, it's perfect... However, after a drive and bit of wet or dirty road, its like a view through a CSI microscope where you can analyise what you see and work out where you have been :blink:
BOOSST
08-09-2018, 05:58 AM #8
08-09-2018, 10:28 AM
One question, is the camera in the LS430 any different to the ones in almost every Lexus/Toyota? Well worth checking out how much the cameras cost for the other models as there's a good chance they will all be roughly the same (perhaps requiring slight modification)
08-09-2018, 10:28 AM #9
08-09-2018, 10:58 AM
parthiban One question, is the camera in the LS430 any different to the ones in almost every Lexus/Toyota? Well worth checking out how much the cameras cost for the other models as there's a good chance they will all be roughly the same (perhaps requiring slight modification)
There really doesn't seem to be any available (on ebay at least). Do many Toyota's come with rear cams?
08-09-2018, 10:58 AM #10
Views 274
23-02-2021, 01:53 PM
Views 312
22-02-2021, 08:48 AM
Last Post by Millo73
