JapCarForum Trade Area Trade Archive Selling Archive LS400 Optitron Dials
25-09-2019, 08:26 AM
I've got a set of dials from my LS400 that I was going to use but I've now changed my mind. They are 'Optitron' gauges so they light up with CCFL tubes and have LED needles. I have the complete cluster, and all the wiring connectors for it with wire tails on. The display also has a small screen in it but I'm not sure you if you can do much with that - it is a separate part inside the dials so easily removable/replaceable.
There is a bit of damage to the 'hood' over the top of the dials but this isn't an issue if you were to swap them into something else.
Don't have a photo of mine specifically but they look like this:
[Image: wpid-100_3393-2011-03-20-01-35.jpg]
This photo doesn't do them justice really, they are REALLY bright!
You can sort of see them in this video
http://www.youtube.com/watch?v=wcn2yFSjeT4
My intention was to fit the dials into the MR2 cluster to achieve something like this:
http://www.youtube.com/watch?v=t_qp40xGeyE
Edited 06-11-2011, 03:11 PM by toxo.
25-09-2019, 08:26 AM #1
09-10-2019, 10:41 AM
ODO was 117,000 miles.
Here are some pictures of the unit. These are quite big images so that you can see detail:
Hood off:
[Image: IMGP3267.jpg]
Hood (some damage top right as you can see - irrelevant if you're installing into an MR2's cluster):
[Image: IMGP3268.jpg]
Rear of unit with main board removed. You can see the membrane wiring for the warning lights, 4 connection points for each dial and the white and red wiring connectors for the CCFL tubes that light up the dials:
[Image: IMGP3269.jpg]
Multi-display is a separate part, easily removed:
[Image: IMGP3270.jpg]
Unit with screen removed:
[Image: IMGP3271.jpg]
Rear of unit with screen removed:
[Image: IMGP3281.jpg]
Rear of unit with main PCB reattached - like the MR2 cluster it uses long screws to transmit signals through to the gauges. This PCB also contains the inverter circuitry for the CCFL tubes:
[Image: IMGP3282.jpg]
Unit completely assembled including multi-display PCB:
[Image: IMGP3283.jpg]
Dimensions:
[Image: IMGP3272.jpg]
[Image: IMGP3273.jpg]
[Image: IMGP3274.jpg]
[Image: IMGP3275.jpg]
[Image: IMGP3276.jpg]
[Image: IMGP3277.jpg]
[Image: IMGP3278.jpg]
[Image: IMGP3279.jpg]
[Image: IMGP3280.jpg]
Wiring Diagram:
http://theshado.ws/images/LS400/instrume.../be-86.pdf
The front of the unit says 1025REV=1MILE.
09-10-2019, 10:41 AM #2
Hood off:
Dimensions:
Wiring Diagram:
07-06-2020, 08:52 AM
Bump...
07-06-2020, 08:52 AM #3
Bump...
31-12-2020, 12:56 PM
Bumpage!
31-12-2020, 12:56 PM #4
Bumpage!
Views 580
11-11-2020, 10:28 AM
Last Post by Manpanzee
Replies 25
Views 2,057
11-04-2019, 08:47 AM
Views 360
25-10-2018, 02:40 PM
