JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Help please urgent
Help please urgent
Help please urgent
Lexuslee
02-10-2018, 08:17 AM
Right made a start on fitting my supercharger today. Got the cradle on and bolted the charger to it, put the pulley on but left the belt off for now. Fitted the linkage cable and called it a day. Put the origanal air box back on and put the air sensor back. Now just took it out and the engine light is on and the trc keeps flashing every few secs. Also if I floor it I loose all throttle control until I turn the car off and wait for a few secs then it works again. Need my car for work in the morning so could really do with some help
Lexuslee
02-10-2018, 08:17 AM #1
rob
02-10-2018, 08:48 AM
hi,
disconnect the cable from the throttle body end and try again. also check your connection to the temp sensor.
when does the fault light come on? as soon as you start car or after you have driven a bit?
disconnect the battery -ve lead to reset everything
rob
02-10-2018, 08:48 AM #2
hi,
Lexuslee
02-10-2018, 09:10 AM
As soon as I start the car , will try what you said and report back cheers
Lexuslee
02-10-2018, 09:10 AM #3
rob
02-10-2018, 09:49 AM
OK then it sounds like the air temp sensor for the airbox, if in any doubt take the connector off and put it back on again.
remember you need to reset the ECU to remove the fault light, the light will not disappear straight away.
rob
02-10-2018, 09:49 AM #4
Lexuslee
02-10-2018, 10:18 AM
How long do I have to disconnect for? Am doing it for 15 right now, will see of this helps. I remember now that I started the car and hasn't connected the sensor. Hope this works or am ******!
Lexuslee
02-10-2018, 10:18 AM #5
Lexuslee
02-10-2018, 10:37 AM
Cheers mate sorted, though I was in trouble then. Ever need anything I owe you 1.
Lexuslee
02-10-2018, 10:37 AM #6
02-10-2018, 11:56 AM
glad you got it sorted mate
02-10-2018, 11:56 AM #7
rob
02-10-2018, 12:06 PM
Lexuslee How long do I have to disconnect for? Am doing it for 15 right now, will see of this helps. I remember now that I started the car and hasn't connected the sensor. Hope this works or am ******!
glad its sorted.... i have done it before so guessed thats what it would be.
for future there are some fuses to pull but TBH its just as quick to disconnect the battery for a few seconds.
rob
02-10-2018, 12:06 PM #8
Views 697
14-02-2019, 10:05 AM
Last Post by lookatmybiceps
