JapCarForum Car Manufacturers Nissan Brakes & Suspension Stagea major Servicing
02-10-2018, 01:00 PM
ok so following on from a discusion here is my list of parts that i will be getting replaced and service items that will be done as i am un sure what the state of service is on it
Oil Filter
Fuel Filter
Water pump
Timing belt
Ancillary Belts
Thermostat
WC34 Stagea RB25DET 6 x Colder NGK Iridium Spark Plugs
And the fluids i will get are
Fuchs TITAN ATF 4400 Automatic Transmission Fluid for Japanese cars - 1 Litre
1 x Fuchs TITAN SINTOPOID SAE 75W-90 synthetic gear oil - 1 Litre
1 x Fuchs Titan Race Pro S 5W-40 Ester Synthetic Engine Oil - 5 Litres
been told the transmission oil was changed just before JAE but was just your every day run of the mill stuff nothing special.
would there be any benefit it doing it again so soon with new stuff ?
any ideas how much of each fluid i should need
and the big question with regards to the cambelt i can get it off ebay but would the garage be fussy over it etc its £50 cheaper that they quoted me...
how much should all of the above cost to have done and what time scale if i deliver all parts at say 8AM to the garage ?
02-10-2018, 01:00 PM #1
Oil Filter
Fuel Filter
Water pump
Timing belt
Ancillary Belts
Thermostat
03-10-2018, 03:36 AM
I have questions!
Is your timing belt an eBay special, or is it Gates/Genuine Nissan?
Did you decide not to do the oil pump?
Does the auto box really only take 1L of ATF? Edit: Oh I see you don't know how much you need... hrm tough one that!
Did you get my text message yesterday?
Edited 14-11-2011, 01:11 PM by toxo.
03-10-2018, 03:36 AM #2
I have questions!
03-10-2018, 04:04 AM
ooh questions lol
the timing belt is a genuine nissan part the add says but i have doubts on things like that from ebay if it goes wrong it will go real wrong
didnt decide not to do it completely forgot about it should i do it ?
i did get your text which one is it asi have spoken to various breakers now...
03-10-2018, 04:04 AM #3
ooh questions lol
03-10-2018, 04:25 AM
The engine will be 5L capacity or thereabouts. The diff will be 1L or thereabouts. Do you know what model the gearbox is? It could be anything from 3L to 8L of ATF...
It was this guy: http://myworld.ebay.co.uk/pennyreds
I would do the oil pump but I am super paranoid. When I've done cambelts in the past I've done oil and water pumps at the same time.
03-10-2018, 04:25 AM #4
clossie
03-10-2018, 04:39 AM
My local indie really wasn't bother that I supplied my own belts and water pump. Times are hard and there's little mark up on hard goods. They just wanted the labour rates.
clossie
03-10-2018, 04:39 AM #5
Views 317
28-10-2018, 12:16 AM
