JapCarForum Cars, Cars, Cars! General Car Maintenance Error code- crankshaft position sensor
RRobert
13-10-2018, 11:04 AM
I did have a little search but didn't find anything, I have P0336 crankshaft sensor A circuit fault coming up via OBD. Anyone got some clue where it is, is it easy to swap the sensor yourself? Any info would be great.
Thanks..
2002 mdl.
RRobert
13-10-2018, 11:04 AM #1
Thanks..
2002 mdl.
13-10-2018, 11:45 AM
Looking at the repair manual it looks very easy:
[Image: 3-DOHCEngine032.jpg]
13-10-2018, 11:45 AM #2
RRobert
13-10-2018, 11:48 AM
Only on my phone and have no access to my handbook , are u meaning there will be info there or is this manual some other book I might not have. Thanks for the link, image don't look too good on phone but I'll look again later at home. Cheers.
RRobert
13-10-2018, 11:48 AM #3
13-10-2018, 11:50 AM
The image turned green for some reason?
Its the step by step guide from the Workshop manual, this one is 4 steps long.
13-10-2018, 11:50 AM #4
RRobert
13-10-2018, 12:23 PM
Had the error reset this evening. Went for a casual drive about 5 miles never same back on (yet). Possible bad earth/ lose wire ??
RRobert
13-10-2018, 12:23 PM #5
13-10-2018, 12:48 PM
Possibly, it will be a IPTA to start if it fails, at least you will know where to start looking, is it worth checking the bolt is tight enough I think they earth through the bolt???
13-10-2018, 12:48 PM #6
13-10-2018, 12:51 PM
They earth through the bolt holding it in.
Have you had anything done in the engine recently?
13-10-2018, 12:51 PM #7
RRobert
13-10-2018, 01:30 PM
Had a service recently but had driven about 40 miles since the service b4 error. hope for a dodgy wire, only thing worse than an intermittent fault is a catistrophic one !!
Sump was replaced as oil plug threaded.
Thanks to all for feedback tho. :thumb:
RRobert
13-10-2018, 01:30 PM #8
13-10-2018, 01:48 PM
I'd be amazed if it ran properly with a broken crank position sensor, so yeah, dodgy wire would be my guess.
13-10-2018, 01:48 PM #9
13-10-2018, 01:54 PM
RRobert I did have a little search but didn't find anything, I have P0336 crankshaft sensor A circuit fault coming up via OBD. Anyone got some clue where it is, is it easy to swap the sensor yourself? Any info would be great.
Thanks..
2002 mdl.
Wasn't it P0335 mate? Either way, glad you have a view to sorting it...
13-10-2018, 01:54 PM #10
Thanks..
2002 mdl.
Views 1,291
29-04-2019, 02:53 AM
