JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Vibrating noise while driving
Pages (4): 1 2 3 4 Next
17-10-2018, 11:53 AM
Right, I've had enough with this friggin noise. I've had the back brakes apart completely and it doesn't look like the handbrake enclosure vibrating.. symptoms are as follows:
Comes on usually within the first 5 minutes of driving, very loud vibrating noise. I can just about feel it through the steering, I reckon it's probably coming from the front. Gets a LOT worse when travelling at higher speeds, it seems to increase in intensity and frequency with the speed of the car (not engine revs).
Completely disappears when I turn left.
Someone help, it's driving me mental and I really want to fix it.
17-10-2018, 11:53 AM #1
17-10-2018, 11:55 AM
Also: Already checked the brake callipers, one of them was sticking but I've refurbed all of them and there is no vibration in the brakes at all.
17-10-2018, 11:55 AM #2
Fozzy
17-10-2018, 11:58 AM
Check the rear drive shafts and cv joints, plus wheel bearings. If the noise is changing as the cars loading changes then its definately something in that area
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
17-10-2018, 11:58 AM #3
17-10-2018, 12:11 PM
I've had a wobble of all 4 wheels, can't feel any up/down play in them. What exactly am I looking for on the rear drive shafts? It came on before I changed the roll bars and we didn't see anything broken looking at the back, so I'll need to know what to watch out for.
17-10-2018, 12:11 PM #4
P.Lindblom
17-10-2018, 01:23 PM
el_bandido Also: Already checked the brake callipers, one of them was sticking but I've refurbed all of them and there is no vibration in the brakes at all.
Sticking brakes often lead to warped discs, which can cause vibrations at certain speeds. Are you sure the discs are ok?
P.Lindblom
17-10-2018, 01:23 PM #5
17-10-2018, 01:26 PM
I did spin the disk of the stuck calliper while the wheel was free, it didn't appear to have bent to any visible degree. I'd also expect to be able to feel that through the pedals? I'll whip the wheels off again soon and double check. Can always replace the disks without wasting too much money.
17-10-2018, 01:26 PM #6
17-10-2018, 02:09 PM
Balljoints? Mine vibrated like crazy at high speeds when my balljoints were knackered
17-10-2018, 02:09 PM #7
17-10-2018, 02:15 PM
I'll replace them and find out! Edit: Car has done 178k Big Grin
Edit 2: How hard to replace are they? Just been reading that I need some kind of press? Is it worth going to lexus and getting them done?
Edited 28-11-2011, 11:55 PM by el_bandido.
17-10-2018, 02:15 PM #8
17-10-2018, 02:32 PM
Could be the ball joint, if you are going down a road with a slight camber, release the steering wheel and see if it suddenly swerves in one direction or the other, if the noise happens more when going over bumps, it could be your anti rollbar droplinks, hope this helps
matt 'sexus' is200
17-10-2018, 02:32 PM #9
17-10-2018, 02:40 PM
Matt - noise does not appear to be affected by the surface of the road, no more than the usual road noise anyway. New drop links were put on with the roll bars so I'm hoping it isn't them!
Edit: Plus the noise started before I changed the roll bars.
Edited 29-11-2011, 12:14 AM by el_bandido.
17-10-2018, 02:40 PM #10
Views 470
24-07-2018, 04:42 AM
Last Post by speedfreek
