supercharger pulley
supercharger pulley
hello all,
just trying to put my kit together and get fitting,but im in need of the water pump pulley,so I can align the cradle up,i cant find one anywhere to buy.
is it that they are from the mercs 130mm water pump pulleys?
any help appreciated guys.
cheers guys,the only one i could get hold of is 138mm,part number 6032050110.dont know if the holes wil line up though,doh.another modification will be needed,might give a little bit more boost if nothing else.turning out to be an epic build haha.
maybee done for christmas.:cursing:
good luck mate! should be good
thanks for the support guys i got a bmw mini turbo r56 intercooler,only wanted a small one to fit under the crash bar,and will need to mod the pipework,but all doable,ive made the intake and outlet for the charger as well as the bov flange for the greddy type rz,keeps the costs down,will hopefully be fitting the cradle this weekend if the pulley turns up and its not raining?
there is a mod for the intercooler as well ive found that uses a couple of windscreen washers that sprays the cooler,sweet,but will leave that until all the rest is done and working,,,,,,,,IFand WHEN haha
buzzard2011 thanks for the support guysi got a bmw mini turbo r56 intercooler,only wanted a small one to fit under the crash bar,and will need to mod the pipework,but all doable,ive made the intake and outlet for the charger as well as the bov flange for the greddy type rz,keeps the costs down,will hopefully be fitting the cradle this weekend if the pulley turns up and its not raining?
I bought a Merc SLK230 water pump pulley for my supercharger build, and I can confirm the one I bought IS NOT the same one as used on the TTE kit for two reasons (I havent seen a TTE pulley, but from the problems I had, I'm only guessing they are not the same)
1 - The holes don't line up, (I had to get the pulley re-drilled)
2 - it sits closer to the radiator. (which would mean the belt would not line up on the TTE kit, but with me having a custom cradle, I ddin't care)
I'll try and find the part number for the pulley I have so you know not to get it by mistake.
