JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension please help asap
please help asap
please help asap
Pages (6): 1 2 3 4 5 6 Next
davidjamesbattersby
20-10-2018, 08:03 AM
i have painted all my calipers last night and put the lexus decals on them but when i have re fitted i thought id flush the old fluid through and put new stuff in while they were off but the brakes are far to spongy now, and when the foot brake is applied i can still turn the rear wheels by hand,, if you pump the pedal a few times it hardens but when you release the pedal and leave it 30 seconds it goes all spongy again, any one got any ideas, iv tried bleeding them over and over but to no avail
davidjamesbattersby
20-10-2018, 08:03 AM #1
20-10-2018, 08:24 AM
Yep you need to bleed the air out from your brake system. You will need a friend to help you out
20-10-2018, 08:24 AM #2
20-10-2018, 08:34 AM
Defo air in the system,
You can buy a cheap kit from Dreaper which allows u to do it by yourself
20-10-2018, 08:34 AM #3
buzzard2011
20-10-2018, 08:36 AM
bleed em again,start at the back then the front,one by one,did you have the engine running when you bled them before?
buzzard2011
20-10-2018, 08:36 AM #4
Phil01
20-10-2018, 08:49 AM
Start at the rear first. But clamp off both front flexi hose because all you will do is compress the trapped air and not get the fluid flowing properly.
Also easier if you have the engine running and let the servo take the work out of pumping.
sent from my Android SGS 2
Phil01
20-10-2018, 08:49 AM #5
davidjamesbattersby
20-10-2018, 08:56 AM
Have tried both engine running and not running. Did right tee left rear front right front left the opposite. Can't see any bubbles at all coming out of any pipe just fluid
davidjamesbattersby
20-10-2018, 08:56 AM #6
Phil01
20-10-2018, 08:58 AM
When you removed the calipers did you clamp any pipes or did you just let the fluid drain so that the reservoir was empty.
Clamp pipes on front and then the rear to establish when you get a hard pedal
Phil01
20-10-2018, 08:58 AM #7
20-10-2018, 09:02 AM
I'd be very surprised if its anything other then air in the system
20-10-2018, 09:02 AM #8
Fozzy
20-10-2018, 09:13 AM
Definitely have to have ignition on to make sure abs solonoids are free from air. Normally LR RF RR LF. I find it works better to pump a few times on pedal with bleed nipple closed, then open it while applying pressure on the pedal.
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
20-10-2018, 09:13 AM #9
davidjamesbattersby
20-10-2018, 09:14 AM
I clamped all the pipes and the resavoir bottle was just under max so just attached them back up put the pads In then bled them as norm
davidjamesbattersby
20-10-2018, 09:14 AM #10
