JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission glowing pre cat !!!! HELP
danielson
23-10-2018, 10:19 AM
:blink:hi my is 200 has just had fitted a de cat pipe 1 week ago felt great for a while lol but went to go to work last thursday and it didnt want to start i got it going in the end and it sounds ruff really ruff the butterfly in the throttle bodie is doing a little funky dance and after driving it one of the pree cats glow and the engine light flashes and stays on sometimes and the traction control button flashies i have disconnected the batt and re conected it but after 15 seconds the light comes back on i have disconected one at a time each coil and they seem fine each one i disconect it cuts out mabe melted cat ??? meow !!!! lol
danielson
23-10-2018, 10:19 AM #1
23-10-2018, 10:40 AM
the pre cat thats glowing is the problem....its melted....either cut the cat out and weld in a straight pipe or find a performance manifold
23-10-2018, 10:40 AM #2
danielson
23-10-2018, 10:44 AM
cheers ormi i will have a go of breaking it up with a bar and hammer tomorrow fingers crossed
danielson
23-10-2018, 10:44 AM #3
23-10-2018, 10:31 PM
wear a dust mask!! you dont want to be breathing in any of it
23-10-2018, 10:31 PM #4
Phil01
24-10-2018, 02:45 AM
Also check if the cat is glowing red hot for an air leak causing a misfire and the unburnt fuel being burnt in the catalyst.
Oxygen+fuel+catalyst=unbeleivable temeratures
sent from my Android SGS 2
Phil01
24-10-2018, 02:45 AM #5
danielson
24-10-2018, 09:24 AM
would it make it run ruff and would it damage anything els never had any problems like this before
danielson
24-10-2018, 09:24 AM #6
rob
24-10-2018, 09:54 AM
danielson would it make it run ruff and would it damage anything els never had any problems like this before
dont know about the car but i would suggest you get another keyboard as you appear to have some keys that are not working. :whistling:
rob
24-10-2018, 09:54 AM #7
24-10-2018, 09:59 AM
Yes the car will run badly, it shouldn't damage anything else - but you never know your luck.
24-10-2018, 09:59 AM #8
24-10-2018, 11:03 AM
rob dont know about the car but i would suggest you get another keyboard as you appear to have some keys that are not working. :whistling:
Yes these people that don't know how to type properly need to go to the bottom of the class Confusedmoke:
24-10-2018, 11:03 AM #9
24-10-2018, 11:40 AM
Moley Yes these people that don't know how to type properly need to go to the bottom of the class Confusedmoke:
Admit it Moley, it took you twelve goes to get that comment properly spelled and grammatically correct.... :lol: :lol:
24-10-2018, 11:40 AM #10
