JapCarForum Car Manufacturers Mitsubishi Workshop - Submit your tips Nissan 350z Changing Oil
14-11-2018, 08:14 AM
I noticed there aren't many tutorials on the web on how to change the engine oil for the Nissan 350z, here is how I do it, please follow the instructions diligently as I am not liable for damage or personal injury. I recommend changing your oil once every 6,000 Kms or 4,000 Miles. I use 5 Litres of Mobil Synthetic 5W30 + Fram Oil Filters, OEM one claims to have a relief valve, but Nissan always likes to make you buy their products =)
Step 1: Warm up your vehicle, dirty oil comes out faster and easier when the oil is hot.
Step 2: Loosen oil filter cap and pull out the oil dip stick, this will also speed up the flowing process. (see step1.jpg)
Step 3: Jack up your car using an appropriate jack and because the 350z is a very low car, its imperative that you use a jackstand and a piece of wood to block one of the wheels so the car doesn't roll off.
Step 4: Remove plastic panel that covers the bottom of the engine. (see step2.jpg) It is held down by screws and plastic clips.
Step 5: Remove the drain bolt and let the oil drain out completely in a oild pan.
Step 6: Install the drain bolt and make sure you use a copper drain plug gasket. (Nissan uses a special copper drain plug that is around 2 mm thick, when you tighten the bolt, the washer thins out. You can get these at your Nissan Parts Counter for about $1 each. Tighten drain bolt at 29.4-39.2 NM or 22-28 FT-LB using a torque wrench.
Step 7: Remove oil filter using oil filter removal tool. (see step3.jpg) You can buy the one from Nissan Part no. KV10115801, its just a simple oil filter wrench that fits perfectly on the oil filter. When installing the new filter, use your fingers and rub some new oil on the filters o-ring. Tighten the oil filter at 14.7-20.5 NM or 11-15 FT-LB.
Step 8 : Wipe off visible oil on the filter and drain bolt area. Re-install plastic cover (see step2.jpg)
Step 9 : Remove Jacks, Wood blocks and Jackstands.
Step 10 : Pour in 4.7 Litres of new engine oil (use a funnel it helps), turn on the car and let it run for a couple minutes. Check for leaks, add additional oil until the oil level is centered (between low and high) on the dipstick.
14-11-2018, 08:14 AM #1
Views 271
25-07-2022, 11:22 AM
Views 420
24-08-2021, 10:32 AM
Last Post by reganlives
Replies 84
Views 4,461
24-03-2021, 04:51 AM
Views 413
19-11-2018, 09:26 AM
Views 518
14-11-2018, 12:18 PM
Views 386
14-11-2018, 08:19 AM
Views 351
14-11-2018, 07:08 AM
Views 474
14-11-2018, 04:08 AM
Last Post by mplavery
Views 416
13-11-2018, 02:41 PM
