JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza 1ggte pistons
1ggte pistons
1ggte pistons
Pages (5): 1 2 3 4 5 Next
Jimbob-T-Lex
Moderator
1,674
16-11-2018, 05:45 AM
Hey all quick question is the 1ggte pistons that are used in the lexus is200 engine as I can get really cheap?
Jimbob-T-Lex
16-11-2018, 05:45 AM #1
16-11-2018, 05:48 AM
They are different I believe.
16-11-2018, 05:48 AM #2
Jimbob-T-Lex
Moderator
1,674
16-11-2018, 05:50 AM
I thought that they were lower compression but used if going to turbo
Jimbob-T-Lex
16-11-2018, 05:50 AM #3
16-11-2018, 05:53 AM
I thought they were the same? Don't you get the lower compression by using the 1GGTE head?
16-11-2018, 05:53 AM #4
Jimbob-T-Lex
Moderator
1,674
16-11-2018, 05:57 AM
Might well be the head but I think the it was the pistons and they can handle great boost because If you use standard internals then you can only run 0.4 boost safely
Jimbob-T-Lex
16-11-2018, 05:57 AM #5
16-11-2018, 05:58 AM
I am under the impression the benefit of the pistons and crank from the 1g-gte is that they are forged, where as the 1g-fe isn't?
Edit: grammar.
Edited 28-12-2011, 03:33 PM by el_bandido.
16-11-2018, 05:58 AM #6
Edit: grammar.
Jimbob-T-Lex
Moderator
1,674
16-11-2018, 06:13 AM
Ok if not to do with low compression then yeah I agree they are forged and beefier so can take more boost off a turbo surely the crank in 1gfe is forged meaning made from one piece
Jimbob-T-Lex
16-11-2018, 06:13 AM #7
16-11-2018, 07:16 AM
I still have a 1g-fe fully forged bottom end here that needs a good home would save you on the labour cost to have the bottom rebuilt as you can just drop it in
Drop me a pm if interested .....
16-11-2018, 07:16 AM #8
Jimbob-T-Lex
Moderator
1,674
16-11-2018, 07:21 AM
Yeah but pricey mate I'm doing almost all myself I just need to know whether it's the 1g-gte pistons and con rods I need as I've got a 1g-fe engine that has done 15000 miles so all is well withit and I'm slowly building it back up in a long time span as funds are low only £500 a month to spend and works out as a gd project
Jimbob-T-Lex
16-11-2018, 07:21 AM #9
16-11-2018, 07:35 AM
1g-gte pistons and rods will fit in a 1gfe.
16-11-2018, 07:35 AM #10
Views 965
23-03-2019, 05:09 AM
Last Post by jameshunter
