JapCarForum General Discussions The JCF Lounge bonnet seals
bonnet seals
bonnet seals
28-11-2019, 05:58 PM
I'm needing a new set of rubber bonnet seals for the IS200 , I have just noticed today that there has been mice eating the seals and they are something that could do a lot more damage . So has anyone got a set and also any advice to keep the mice away ? And before anyone suggests getting a cat well just NO .
28-11-2019, 05:58 PM #1
Fozzy
28-11-2019, 06:01 PM
once mice get into a car they can be a nightmare to remove. Try and find out if they are nesting somewhere and destroy it. I dont think there is that much you can do about it, unless there is some sort of deterrant spray to keep them away.
For the seals i would have thought a breaker would be your best bet, cant imagine they will be cheap from Lexus
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
28-11-2019, 06:01 PM #2
28-11-2019, 06:07 PM
Hey moley you can get some pest detergents that plug into the mains we live in the country Ish and field mice are a real pain we have a few of these dotted around the garage and house etc works a treat not seen any for a while now lol
Works on ultransonic frequencys
28-11-2019, 06:07 PM #3
Fozzy
28-11-2019, 06:16 PM
ah didnt think of that, if the car is garaged
Fozzy
28-11-2019, 06:16 PM #4
28-11-2019, 06:20 PM
If its not garaged then youn can run an extension lead out and position it in a ip rated box put the repellant in the box
Also ensure the cable ir protected by a rcd
28-11-2019, 06:20 PM #5
28-11-2019, 06:22 PM
No the car just sits outside at the moment. So plug in stuff won't work
28-11-2019, 06:22 PM #6
28-11-2019, 06:25 PM
It can work if you place in a waterproof box places like b&q sell outdoor sockets that come with a rcd plug in module so you can make your own one up and just throw it under the car bit like the ghostbusters ghost trap thing lol
Or how far from the house is the garage as these things normally have a range of 20m I think.....
28-11-2019, 06:25 PM #7
28-11-2019, 06:45 PM
i have the full set of seals i think mate
28-11-2019, 06:45 PM #8
28-11-2019, 06:51 PM
I'll buy them off you then stav , if you don't need them.Rabs my car is not in the garage it just sits outside my front window of the house. So would one of them things plugged into the living room work
28-11-2019, 06:51 PM #9
28-11-2019, 06:53 PM
Yeah I think one would work it's called a rodent repellant they should have a range on the box so check that before getting it.
But not had any round mine for some time now yay lol
28-11-2019, 06:53 PM #10
Views 988
06-03-2021, 04:33 PM
Last Post by jomo
Views 499
17-12-2017, 06:10 PM
