JapCarForum Club Sponsor MeisterR Club Discount and RRP Price Adjustment in March
MeisterR
15-12-2018, 06:45 PM
As a trader on the OUTLAW Forum, I would like to offer a 10% discount to OUTLAW Members on MeisterR Coilovers.
I have not set a date on when this offer will finish, but I will give ample warning before I take the offer off.
How to get discount off MeisterR Coilovers?
Simple order the coilovers out want from our CyberSpeeds Webshop.
http://www.cyberspeeds.com
On Check Out, just enter the voucher code OUTLAW
This will apply the 10% discount... Simple. Smile
Advance Notice:
Due to raising cost, the RRP of the MeisterR Coilovers will be adjusted at 1st of March.
Therefore if anyone is interested in getting coilovers, it would be good to try to purchase them before the RRP goes up.
MeisterR
15-12-2018, 06:45 PM #1
Advance Notice:
MeisterR
27-12-2018, 10:09 AM
Just an Early Reminder that price will go up in March.
MeisterR
27-12-2018, 10:09 AM #2
27-12-2018, 10:12 AM
can you offer info on the 350z ones any reviews on them etc
27-12-2018, 10:12 AM #3
MeisterR
27-12-2018, 10:27 AM
Rabster can you offer info on the 350z ones any reviews on them etc
We done a few 350Z already.
We have 2 specs, Zeta-S and Zeta-R
Zeta-S: Standard in-board rear springs fitment.
Bolt straight on to the car, and will do pretty much everything well.
Pretty much same as most coilovers you see fitment wise, but of course with our specification.
Comes with Front and Rear Aluminium Top Mount with Rubber bush insert.
Springs rate are: Front 10kg/mm, Rear 8kg/mm
Zeta-R: True Coilovers fitment with the rear springs relocated to the dampers.
Bolt on to the car, comes with a new adjustable rear lower arms that will replace the standard lower arms, will also allow adjustments of the rear toe.
This retain the dual perch design and allow easier adjustments and springs rate changes in the rear.
The front is the same.
Springs rate changes in the rear is because of the relocation, the actual wheel rate will remain near to the Zeta-S setup.
Comes with Front Pillowball Top Mount and Rear Aluminium Top Mount with rubber bush insert
Springs rate: Front 10kg/mm, Rear 5kg/mm
Both have been tested and will work well, depends on what you want to do and your budget.
If you really want to lower your car, the Zeta-R is a good one to go for as it will make it easier, retain more travel, and also give proper toe adjustments were the standard arms can run out.
MeisterR
27-12-2018, 10:27 AM #4
MeisterR
03-01-2019, 10:47 AM
Another bump with 2 weeks or so to go.
Just a reminder before the price goes up. Smile
MeisterR
03-01-2019, 10:47 AM #5
MeisterR
12-01-2019, 11:58 AM
Just another reminder that another weeks to go before RRP price goes up.
So if you are interested in something let me know and I'll try to sort you out. Smile
MeisterR
12-01-2019, 11:58 AM #6
MeisterR
18-01-2019, 12:47 PM
A Few members said they need a little more time.
So I won't raise the price until next week just to give everyone a little more time.
MeisterR
18-01-2019, 12:47 PM #7
MeisterR
24-01-2019, 11:03 AM
Okay, I will put the price up at the end of this week.
So here is a final "head up" for everyone.
If you want in on the deal, before the weekend would be the cheapest time to do so. Smile
MeisterR
24-01-2019, 11:03 AM #8
24-01-2019, 11:26 AM
What's the best price on the 350z shocks including fitting etc
24-01-2019, 11:26 AM #9
MeisterR
24-01-2019, 11:31 AM
Rabster What's the best price on the 350z shocks including fitting etc
I don't actually do fitting, but I do have local affiliate who can.
Where are you located?
Also also depends on what type of fitting you want, and do you want tracking also?
Finally, I have 2 different type for 350Z (Zeta-S and Zeta-R).
Depends on what you need... Zeta-S will do the job for most people...
Zeta-R is a bit of trick kit as it convert the rear in board springs to a true coilovers setup.
Let me know and I'll try to get you some quote. Smile
Best Regards,
Jerrick
MeisterR
24-01-2019, 11:31 AM #10
Best Regards,
Jerrick
Views 103
27-05-2023, 06:12 AM
Last Post by MeisterR
Views 198
06-11-2022, 01:28 AM
