JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Induction kit help/advice or tips.....
lil_rob
19-12-2018, 08:50 AM
Hi there guys just a quick question i have made and fitted my own induction kit as many of us is200 owners have.....
my question is, the air flow meter sensor (or what i assume it is) plugs into the side of the standard airbox obviously there is no place for this with the induction kit..... it has brought on my engine management light and i was just wondering what the remedy is for this? Do i just simply drill a hole in either the alloy pipe or one of the silicon hoses and mount in there? from what i can see i would have to extend the wires on the loom to do this..... one of my friends has told me if the car uses a cambus system i cannot do this as it works on voltage or something? i am more into mechanics then electicals so its not really my forte
Also there is a breather pipe that plugs into the airbox what do i do with this do i just block it off? leave it hanging or do i agen have to adapt what i have already made to accomadate it?
anyone that has already done this or has any idea what i should do any advice would be great help
Cheers guys
p.s sorry if its abit of a dunce question just want to make sure i get it right
lil_rob
19-12-2018, 08:50 AM #1
Cheers guys
19-12-2018, 09:07 AM
The intake temp sensor. Yes you can extend the wires, most drill a small hole in the silicone and put it there
The breather, pull the pipe off and put a small filter onto the plastic pipe coming from the engine head
19-12-2018, 09:07 AM #2
19-12-2018, 10:29 AM
With the sensor if you take off the rubber surround from the old air box then cut a hole in the silicone pipe and fit that it will hold the sensor better.
19-12-2018, 10:29 AM #3
lil_rob
19-12-2018, 11:40 AM
brill cheers for the advice guys breather should be pretty simple.... as for extending the wires does it have to be any particular wire or does it not carry many volts? would simply speaker wire do or will it just melt under the conditions? only asking as i have abit of old speaker wire kicking about......
thanks agen guys Smile
lil_rob
19-12-2018, 11:40 AM #4
19-12-2018, 11:47 AM
Speaker wire will do mate. Not visually great but will do the job
19-12-2018, 11:47 AM #5
lil_rob
19-12-2018, 11:59 AM
cheers mate yeah i can imagine :/ will do until i can get down to halfords or local diy shop..... will i have to reset the engine management light (no a problem can plug it in at work) or will it go out automaticly?
sorry bout all the questions lol
dont suppose you would happen to know what size filter would need for the breather? as im not with car at the min if not is not a problem.... by memory from look of the pipe would say was about 25mm just want to make sure cos will order one now
lil_rob
19-12-2018, 11:59 AM #6
lil_rob
19-12-2018, 12:18 PM
ok then i will order the 16mm one i have seen.... the light is already on cause i started it..... couldnt wait to see what it sounded like lol
lil_rob
19-12-2018, 12:18 PM #7
lil_rob
19-12-2018, 12:27 PM
thats fine we got a bosch kts diag computure at work so will just sort it all out then erase the error codes..... obd port is under the bonnet by the near side headlight isnt it? yeah i think it would be around 20mm external diamiter as the hose walls are quite thick arnt they so 15mm sounds about right
lil_rob
19-12-2018, 12:27 PM #8
Views 965
23-03-2021, 07:29 AM
Last Post by kaykay
Views 1,072
23-08-2018, 01:01 PM
Last Post by sprinter2012
