JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza tte front bumper
tte front bumper
tte front bumper
Mikey
06-07-2016, 06:48 AM
is the tte front bumper any lower to the ground than standard as i want to get a new /secondhand bumper or will fitting the lip/skirt on the front be lower
Mikey
06-07-2016, 06:48 AM #1
06-07-2016, 06:52 AM
Mikey is200/s13 is the tte front bumper any lower to the ground than standard as i want to get a new /secondhand bumper or will fitting the lip/skirt on the front be lower
It is a bit lower than standard but not a huge amount - I would've thought it's about the same level as the standard bumper with the TRD lip.
06-07-2016, 06:52 AM #2
06-07-2016, 07:08 AM
not sure if this will help but heres mine on stock springs with a TTE bumper, I don't have any issues with speed humps and next to standard curbs its probably a inch clearence.
[Image: DSCF2686.jpg?t=1250523709]
06-07-2016, 07:08 AM #3
06-07-2016, 07:34 AM
when i had one on mine it sat approx 10mm lower than the stock bumper iirc, due to the ends, but in the centre it was pretty much the same height?
06-07-2016, 07:34 AM #4
russelllinn
06-07-2016, 08:35 AM
Bandit when i had one on mine it sat approx 10mm lower than the stock bumper iirc, due to the ends, but in the centre it was pretty much the same height?
I'd say as above, I have mine on with it lowered on TTE springs and no probs with speed bumps etc.
russelllinn
06-07-2016, 08:35 AM #5
Mikey
07-07-2016, 12:01 AM
cheers guys
Mikey
07-07-2016, 12:01 AM #6
cheers guys
07-07-2016, 04:42 PM
i have the 40mm springs on mines and no probs with bumps. but need to watch when parking as the pavment will scrape the bumper
07-07-2016, 04:42 PM #7
Views 234
01-07-2020, 04:42 AM
Views 629
27-02-2020, 12:02 PM
Last Post by mattlaw
Views 397
06-01-2020, 12:49 AM
Last Post by Matt_C
Views 728
02-08-2019, 08:39 AM
Last Post by jasons
Views 321
28-07-2019, 04:57 AM
Last Post by Matt_C
Views 348
19-07-2019, 12:48 PM
Last Post by Chris0121
Replies 85
Views 5,275
20-05-2019, 10:57 AM
Last Post by sprinter2012
